how do you bleed a clutch?
Woodie
one more thing on my 1970 midget ...How do you bleed the clutch. if you have pics that would be great too!!
And by the way I figured out the distributore and coil and generator wiring today based on input from you guys ...THANKS!!!
als
I have a 76 and there is a bleeder valve on the back end of the clutch slave cylinder which is mounted in the bell housing.
I'm not sure if the 70's are the same, but its worth a look.
Good luck.
Al /ubbthreads/images/graemlins/canpatriot.GIF
jlaird
I think they are all the same, takes two folks. There is a hole in the tunnel for this job.
Yes there is an access hole in the passenger foot well. It is a two person job and can be very aggravating or very simple depending on how your luck runs. I f you have access to a mity vac or a pressure bleeder, that is easiest. If not, then you have to blled it like a brake system. Pump, hold, open bleeder, foot goes to floor, close bleeder, repeat two million times until there are no air bubbles. It is adviseable to push the pushrod into the slave cylinder to eliminate the possibility of an air pocket there. If you search the threads, you can probably find many discussions on this. Good luck.
Woodie
Woodie
I have the car on axel stands right now, can I get at the bleed valve from under the car? I can reach in and push the cluth down by hand.
If the car is right hand drive you can "easily" do it by yourself. However, unless you have freakishly long arms, you will most likely need an assistant. (This is one reason I finally bought a pressure bleeder.)
Woodie
Woodie
well friends call me strange for buying a british car, but I have my brother in law helping me
kcbugeye1275
I've done it by myself on the bugeye back when I had a bad slave cyl. It really can be done by one person sitting in the drivers seat without the car being on jack stands. Pull that rubber plug out of the tranny cover and check out the slave and get the feel of the position needed for the wrench on the bleeder. I think when you get under the car you will see that you aren't really quite in the right position to get to the bleeder. While we're having this discusion, go to the parts store and pick up a cheep bleeder botttle, check valve and hose. Keeps fluid from going where you don't want it, you can easily see if you have any air bubbles, and you can see the condition of the fluid you are bleeding. I have thought of the pressure bleeder, and it is simple to build one, I jsut haven't done one yet. Now, the next issue, castor BF, or synthetic? Good luck and let us know how it turns out.
BTW, I think if you remove the front right wheel you can reach the bleeder from there.... or maybe I'm thinking of a different car... but you can look and see.
Kurtis
[ QUOTE ]
[/ QUOTE ]
I don't think you can get a wrench on the bleed valve from underneath the car. In fact, the only way I could get a wrench on the bleed valve on my Bugeye (through the access opening) was to use a mini-breaker bar and a socket. Because of the angle of the bleed valve and clearance issues with the edge of the access opening, I couldn't get a box wrench (not even an offset box wrench) on it.
regularman
If you cannot get it to bleed any other way, there is another way that I had to use on my 71. I must have put a quart of brake fluid through it and still it would not bleed because there was air in the line and the line goes up and over and acrros and then down to the slave. I talked to a brit who used to race rallys and he said to use the brake wheel cyinder as a pump. Connect a piece of rubber tubing to the bleeder of the brake wheel cylinder to the bleeder on the clutch slave. Open both bleeders and loosen the connecion at the clutch master cylinder and then press the brake pedal until all the air comes out the top at at the clutch master cylinder. Then tighten the bleeder screws and then the connection at the clutch master cylinder. I tried it and it worked like a charm. Of course they make a proper brake pump for the job, but I didn't have one and that worked fine and comes in handy on the road if you need it.
lesingepsycho
Here's how I do mine and perhaps I'm crazy for doing it this way but it's the only way I could figure to do it myself without it taking FOOOOORRRRREEEEEVVVVVVEEEEERRRRRR
so here'goes...
From underneath the car I remove the two 9/16ths bolts that hold the slave cyl to the trans as well as detaching the fork so that the slave will simply hang there. Then, I open the bleeder, press the rod in with my hand forcing fluid/air out, then close the bleeder and as I let the rod back out it draws in fluid from the reservoir. Doing it this way allows me to do it by myself and make sure I get rid of any pesky air bubbles in the slave cylinder. The only annoyance is topping up the reservoir for every two pumps. Afterwards, just reassemble and you're ready to go.
My dad and I used to always do it the two person pedal-pumping way and it never seemed to get the firmness that one would expect. After my dad passed I needed a way to do it myself and I came up with this method which seems to yield better results anyway.
JACK
zimmy
u can also stuff ur arm in beside the motor and bleed it with a small wrench....gets easy after you do it 1000 times! ; ) watch for the bubble trap in the highest part of the line.........
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
WHT Remote Clutch Slave Cylinder Bleed Extension Austin Healey 11
G Brake/clutch resevoid replaced do I have to bleed the system Austin Healey 9
Jim_Gruber Did my clutch just bleed itself? Spridgets 11
K TR4/4A Hey CJD...gravity bleed clutch MC and slave? Triumph 6
princetn1 MGB Clutch Bleed MG 3
M General MG Midget clutch bleed - engine out MG 3
trotti Access to the clutch slave cylinder bleed screw Austin Healey 41
K TR2/3/3A Clutch bleed using"gravity bleed" method? Triumph 4
K TR2/3/3A TR3A with TR6 trans Clutch Bleed Issue Resolved. Triumph 6
K TR2/3/3A TR3A Clutch Slave Bleed Issue? Triumph 8
K TR2/3/3A TR3 Clutch master and slave bleed issues? Triumph 5
R T-Series Still No Luck With Clutch Bleed MG 15
D clutch bleed ? Spridgets 2
steved033 Clutch stuck, a bleed doesn't help. Austin Healey 20
SCguy bleed clutch? Triumph 3
R T-Series MGB Clutch Bleed Solution MG 5
RedTR3 TR2/3/3A TR3 Clutch slave bleed screw size Triumph 4
K TR2/3/3A Another brake bleed question....... Triumph 17
bugedd Bench bleed tips Spridgets 14
W TR4/4A Hydralic bleed Triumph 4
T TR2/3/3A Bench Bleed Girling Master Cylinder Triumph 2
AngliaGT 1275 - Just HOW Do I Bleed the Slave Cylinder? Spridgets 4
T TR2/3/3A Only women bleed Triumph 8
M Bn-2 Windshield Seal Paint Bleed Austin Healey 8
jlaird Brake bleed niples Spridgets 34
D BN2 master cylinder bleed Austin Healey 2
B Bleed Screws Spridgets 2
bugedd Brake bleed question Spridgets 9
bugedd Brake bleed screws Spridgets 6
nevets How to clean a E Z Bleed ? Restoration & Tools 11
John_Mc Bench bleed slave cylinder? Triumph 4
M Rocker Arm without Oil Bleed Hole Austin Healey 4
eschneider xj6 purge valve / air bleed valve Jaguar 4
Trevor Jessie Eezi-Bleed Tech tip Spridgets 1
Z TR6 Can't seem to bleed TR6 brakes Triumph 10
jjbunn Missing Bleed Nipple? MG 6
A Brake bleed Austin Healey 3
glemon Help Cant Bleed Brakes Triumph 15
1 So, I need to bleed my brakes on 60 BE.... Spridgets 3
T Any tips on how to bleed brakes?? Triumph 16
2wrench Speed bleed tool Triumph 15
jerrybny Master Cylinder Bleed Kit Triumph 8
jerrybny master cylinder bleed kit Restoration & Tools 2
MrPandy Bleed the oil pressure gauge? Triumph 5
I Brakes won't bleed Triumph 14
A BJ8 Blake Bleed Mystery - Low Fluid Flow Austin Healey 3
S Brake Bleed after Servo Installation Austin Healey 4
G Teflon tape on bleed screws Austin Healey 13
K Brake Bleed Screws Austin Healey 12
