duplaga1952
Member
i did the extention from the slave cyl. as chris sugested per my other post. put the bleeder screw in a clear plastic spray can lid and kept completely submerged. took excess fluid out of the cap w/ turkey baster, replaced in clutch master cly and pumped clutch pedal w/ a stick. bubbles came out and stopped continued process for 20 mins . no movement on the push rod into the slave. kept it up for an hour , checking pushrod every 10 min. no luck. any insite? may be the last warm day for awhile
thanks bob 68 sprite
