TR4/4A Hey CJD...gravity bleed clutch MC and slave?
karls59tr
Bronze
I reread one of my old posts on gravity bleeding and you said that the MC should be "primed" before doing this to prevent an air bubble in the cylinder. Did you mean to bench bleed the MC first or is the air bubble normally trapped in the slave? I already have the slave set up on the gearbox ready to go but the master is not connected as I'm waiting for a pipe connector from Moss. I haven't had any luck with the other bleed methods so I'm going to try the gravity bleed.
Karl
Geo Hahn
Not CJD - but FWIW, I never do a bench bleed. In the unlikely event that the MC seems to need a prime I just crack open the outlet line and pump slightly until some fluid comes out.
TomMull
Not CJD here either, but as long as the master is sucking fluid, it will bleed. It is very easy to bleed also, by any means, at least in my experience. Here's a variant of the gravity method suggested to me by a local club member: Seal the bleeder with Teflon tape. Push a 1/4 hose on the nipple and lift the hose above the master cylinder. Pump a little to get it started then let gravity do it's thing.
Tom
CJD
Hey, it's me! Wife's in the hospital, so I've been sitting with her with nothing better to do than surf the forums!?!
All I meant is that sometimes the master cylinder occasionally traps enough air that the siphon won't start. I did the TR2 last month, and the master primed with a few slow pumps of the pedal (in the car). Once the fluid starts down the line, then gravity takes over. It's not as fast as doing it with a partner...but it'll get it done.
sp53
I am not CJD either, but whatever he said goes double for me.---- Back in the day with older type brake fluid, some old school guys would crack the zerks to let a slight drip of fluid out and just let all 4 bleed out to get any water out that was attracted by the fluid.
kodanja TR2/3/3A Hey Its been a while Triumph 5
JPSmit Hey Tom! Other Cars 15
Keoke Hey Use guys Austin Healey 1
Basil Admin Note Hey Joe Reed! Your watch MG 4
Keoke HEY!! Austin Healey 2
Mickey Richaud General MG Hey, Drew! MG 2
Keoke Hey !!! Austin Healey 7
W Hey Drew.... Spridgets 27
Mickey Richaud Hey, Walter! Other Cars 4
Mickey Richaud Hey, Walter! Other Cars 1
Mickey Richaud Hey - J-P! Other Cars 3
J TR5/TR250 Hey Pat, you are getting behind Triumph 0
Mickey Richaud Hey, Tom [Nutmeg] Other Cars 2
Mickey Richaud HEY, Nial! Other British Cars 6
Mickey Richaud Hey, J-P! Other Cars 7
5 hey new here Other British Cars 6
Mickey Richaud Hey, Paul [Brosky] - Triumph 2
JPSmit MGB-GT Hey Mickey - here's a mod for the GT MG 10
J Hey, Northern California Healeys Austin Healey 0
Sherlock Hey Walter! More IHC trucks for you Other Cars 4
Mickey Richaud Hey, Tom [Nutmeg]! Other Cars 3
JPSmit Hey Billy! Other British Cars 5
Mickey Richaud Hey, J-P Other Cars 11
Mickey Richaud Hey, J-P! Other Cars 10
Cottontop Hey, Healey Rick.... Austin Healey 1
A Reversed battery posts?? Hey Pat, get this! Triumph 35
Morris Hey JP...OT Spridgets 7
JPSmit Hey Doc!!! Other British Cars 3
JPSmit Hey Nial Other British Cars 2
gsalt57tr3 hey all Triumph 10
AngliaGT Hey Doc - Did You See This Cortina? Other British Cars 1
DNK Hey Andy Triumph 9
JPSmit Hey Theron Spridgets 4
DNK Hey Doc Lotus 1
Mickey Richaud Hey, Nutmeg! Other Cars 1
JPSmit Hey Morris Spridgets 3
JPSmit Hey Mickey!!! MG 4
JPSmit Hey Jack - you neeeeed this! Spridgets 5
jdubois Hey, at least she kept failing in style! Triumph 6
Mickey Richaud Hey, Basil - Other Cars 8
DNK Am I a Fool? [Hey, Rhetorical Only!] Triumph 18
G Hey JP Spridgets 1
Mickey Richaud Hey, Doc and Mark II Other Cars 5
JPSmit Hey Doc & Mark Other Cars 16
Mickey Richaud Hey, RANDY! Triumph 1
JPSmit Hey Drew! Spridgets 9
vping Hey an Latest from VPING!! - My '63 MG 2
DNK Hey Lotus 18
G Hey Hap, got $25 ??? Spridgets 16
JPSmit Hey Phil!!!! Spridgets 5
