TR2/3/3A TR3A Clutch Slave Bleed Issue?
karls59tr
Bronze
I can't seem to get a firm pedal no matter what I try. I'm beginning to think thst an air bubble is being sucked back up the Slave to Resevoir Line when the pedal goes back up during bleeding? Can I bleed the MC where it sits rather than bench bleed it? How is this done? The slave cylinder is new(have there been any issues with Moss slave cyinders?).....pushrod is in 2nd hole on the lever and the adjustment of the rod has been done. I only get decent pedal firmness by pumping the pedal to build up pressure. Any suggestions
Darrell_Walker
Just checking, did you make sure to mount the slave with the bleed nipple above the connection to the master? Easy to to reverse, and leave a bubble in the slave that you can't get out.
Tinkerman
I'm standing on the floor of the shop looking down into the engine compartment (hood is not on yet). My bleed screw is underneath the master inlet. Are y'all saying that it should be the other way around? Thanks Tinkerman (Dick)
Darrell_Walker
Yes, it should be at the highest point, since the air will rise.
MGTF1250Dave
Aloha Karl, I have used a small syringe to add hydraulic fluid to a master cylinder. I removed the pipe at the output side and slowly added fluid through the output port until it was topped up. Be extremely careful of spills if you use DOT 3 or 4 fluid (AKA paint remover). A plastic glue applicator from a home improvement store will also work.
charleyf
I just helped a buddy rebuild and bleed his master ( M/C) and slave cylinders. We were not getting any fluid into the clutch M/C until he pulled out a thing that he made. It was a reservoir cap with a bicycle tire valve bolted into the top. We put that on the reservoir and used about 5 -10 pounds of air pressure and were then able to bleed the slave cylinder in very short order. I am guessing that the one push of air into the resrvoir did the trick for both the clutch and brake systems as we had rebuilt the brake M/C also.
Charley :encouragement:
K
karls59tr
Bronze
Well I installed a one way valve "Speedbleeder" in the the clutch slave to assist in the bleeding process. No air bubbles...I managed to get a 1/2 to a 1/3 hard pedal so I assumed I was good to go as it seemed to shift into gear OK. After awhile it would occasionally be stiff in shifting from 3rd to 4th and sometimes it would hang up and not go into gear.....pumping the pedal helped get into gear. sometimes the pedal would be very close to the floor before engagement.! Checked the reservoir and it was still topped up. A) is it possible I'm not adjusting the pushrods properly?....do you push the clutch operating shaft lever back(towards rear of car) just till it stops....then adjust the pushrod until the clevis fork matches up with the 2nd hole in the lever and the other end of the pushrod is just touching the slave piston and then make the 2.5mm adjustment? can this be done with the return spring off....then hook up the spring? how can the adjustment be done if the spring is hooked up as you won't know when the pushrod is just touching the piston?B) if I managed to install the release bearing backwards would that throw off the clearances in clutch lever movement so that I would have the clutch issues I described? C) If there are no air bubbles in the slave,MC or line what else could cause these issues?.....maybe the hydraulic rubber hose from the slave is partially collapsed? any advice most appreciated Karl
TR3driver
Great Pumpkin - R.I.P
Not "just touching"; you want it pushing firmly on the piston so the piston is bottomed in the slave cylinder. The instructions tend to assume that the return spring bottomed the piston, but it might not if your return spring is stretched or weak.
Offhand, having the adjustment way off combined with a return spring that doesn't always do it's job is the only cause I can think of that fits your symptoms. But having something assembled wrong might explain the adjustment being way off (so far off that it doesn't have enough range to make it right).
K TR2/3/3A Complicted Clutch Slave Problem TR3A Triumph 12
M TR2/3/3A Position/Adjustment of TR3A Clutch Slave Cylinder Triumph 20
K TR2/3/3A TR3A Clutch MC stop bolt and clutch slave adjust Triumph 5
MGTF1250Dave TR2/3/3A Help with TR3A Clutch Slave Cylinder Triumph 3
T TR2/3/3A TR3A clutch problem Triumph 15
C TR2/3/3A TR3A clutch/brake cylinder rebuild Triumph 4
angelfj1 Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS Triumph Classifieds 4
angelfj1 TR2/3/3A 59 TR3A Clutch Master Cylinder Failure Triumph 19
K TR2/3/3A TR3A with TR6 trans Clutch Bleed Issue Resolved. Triumph 6
M TR2/3/3A TR3A clutch hydraulic problem Triumph 9
T TR2/3/3A TR3a Clutch Pedal Return Triumph 2
M TR2/3/3A TR3A Clutch Bleeding Triumph 17
L TR2/3/3A TR3a Clutch cylinders Triumph 16
K TR4/4A Can I put a TR3A Clutch in a 4A? Triumph 16
T TR2/3/3A TR3A clutch&brake master cylinders Triumph 11
H TR2/3/3A TR3A Clutch Ratteling Triumph 3
Tinkerman TR2/3/3A TR3A Post 60000 Clutch M/C to Reservoir Line Triumph 6
H TR2/3/3A TR3A clutch ratteling Triumph 2
Tinkerman TR2/3/3A TR3A Clutch Pressure Plate Triumph 2
K TR4/4A TR3A and TR4A clutch pressure plate...Difference? Triumph 2
NutmegCT TR2/3/3A clutch pedal "snap" - TR3A Triumph 9
MGTF1250Dave TR2/3/3A TR3A Clutch Hydraulics Triumph 8
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
