AutoAnglaise
Hi !
I have changed the hose between the reservoir and the master cylinder.
I bled the brakes 4 times (the first time using an Eezibleed and the 3 others using the classical method). After finishing the bleed, I try the car and the pedal is always spongy (the first time is spongy and the second time is harder).
Every time, I have air when I bleed the brakes. I have used 1.5 L of brake fluid (DOT 4).
I think there is some air in the brake system but I do not know why. There is no leak around the bleeders and the master cylinder.
Could you give me advice to resolve this problem ? Thank you.
Bye.
Bye.
