Brake Bleed after Servo Installation
Scot
I just had my Girling brake servo rebuilt by a professional rebuilder and I have now reinstalled it back in my BJ8.
My question relates to bleeding of the hydraulic system after the sevo is back in.
Is there anything special I must do to bleed the sytem after such a replacement or just bleed normally? I have talked to others about this and they have had limited success. Alot are getting air in the system after bleeding and some talk about bleeding the sevo itself although mine has no bleed nipple.
Would it help to start the car and pump brakes after the first bleed and then repeat the proceess?
Any help or experience on this appreciated. /ubbthreads/images/graemlins/confused.gif
Keoke
Hi Scot, I have replaced the original servo on my 1966 BJ8 after it was rebuilt and simply bled the brakes in the usual manner ,no problems were encountered-FWIW---Keoke
RF Thom
When you bleed the brakes make sure you have the engine running [ vacuum on servo] otherwise you can get an air lock inside the servo master cylinder. That's right there are in essence two [2] master cylinders - 1st at the peddle and the 2nd on the servo. Without vacuum the servo master will not operate or go full stroke expelling any trapped air inside. This is from experience.
Regards, Bob
S
Scot
Thanks for the tips guys. After a normal bleed I started the car with a firm pedal and all checks out OK on a test drive.
Keoke
Thom;
Never had that problem after servo rebuild and reinstall.Regards Keoke /ubbthreads/images/graemlins/driving.gif
K TR2/3/3A Another brake bleed question....... Triumph 17
G Brake/clutch resevoid replaced do I have to bleed the system Austin Healey 9
jlaird Brake bleed niples Spridgets 34
bugedd Brake bleed question Spridgets 9
bugedd Brake bleed screws Spridgets 6
A Brake bleed Austin Healey 3
K Brake Bleed Screws Austin Healey 12
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
bighealeysource Brake Master Cylinder Austin Healey 27
