Teflon tape on bleed screws
G
Just a quick question for you guys who use teflon tape on brake bleed screws. Do you wrap all the threads with it or just part way down? Im concerned about it coming off the lower threads and fouling up the wheel cylinder.
Thanks,
jv
/ubbthreads/images/graemlins/confused.gif /ubbthreads/images/graemlins/hammer.gif /ubbthreads/images/graemlins/cheers.gif
jayarbee
Member
I have used this method many times with no problems. Knowing that using teflon tape on systems where it is not good for the tape to enter, I take care to use only enough tape to seal the threads, and preferrably at the top, as you noted. Another, but messy method is to use RTV on the threads--really messy.
Geo Hahn
I cut the tape lengthwise so it is about 3/16" wide. Since one would rarely remove the bleed screw unless doing a rehab of the cylinder or caliper, being conservaitve with the tape may be enough to avoid getting anything into the system.
G
Geo,
Your previous post on cutting the tape down the middle is what got me thinking about that. Half the threads are shiney and the other half are soiled from being exposed. Should I take the tape 1\2 way down the shiney threads or is that to far?
Jayarbee,
I try to stay away from blue rtv. The DPO (or their mechanic) of my Sprite used so much of it working on the engine that when I tore the engine down after oil starvation problems I found it covering the oil pick up screen in the sump and almost completely blocking the oil way from oil filter to block. Needless to say I have developed a prejudice against Blue RTV!
Thanks for the help fellas
jv
bighly
Dosent this get all buggered up when bleeding? I loosen/tighten at least 10 times when bleeding.
Seems like the tape would be desintegrated by then.
Maybe I am just a bit confuse-afied.....
ThomP
What is the point of using the tape? Bleed screws have a seat that they seal on at the end of the screw. The threads are NOT part of the active seal. The bleed screw is not tapered like pipe thread where the tape is an active seal. If the bleed screws leak (I have never seen one) then the seats must be buggered. Replace the screws and/or resurface the seats in the cylinder. If you are worried about siezing; don't over tighten the screw. They don't need to be torqued to the full capability of the wrench.
Bruce Bowker
I would also suggest not using the tape in these circumstances. It will not help seal. Only value is to maybe and that is MAYBE prevent future freezing up but I doubt it will even help that. As said already, losening and tightening when bleeding will most likely make the tape that much more usless.
ThomP
Anti-sieze is good stuff, EXCEPT it contains petroleum and that is NOT good for brake systems. If you were very careful with it and did not use too much, it should work fine.
Dave Russell
Yoda - R.I.P
[ QUOTE ]
[/ QUOTE ]
"Some" people use vacuum bleeding from the screw end of the system. It works quite well if the screw threads are sealed so that air can't get into the vacuum. The tape also keeps the screws from rusting/corroding into the cylinder, if like some of us, you don't bleed the brakes more than once every five years. To each his own.
WALTER
The plastic vacuum pumps, like the one Moss sells are great. One person bleading with no problem.
RF Thom
JV The use of RTV is oversold. I like to parallel it's usage to soldering. It will enhance a good sound mechanical joint - it will not fix it. Try soldering an oil covered pipe - no go. RTV should be used to enhance joints where the gap is over 0.003" but works better at gaps of 0.02". RTV has good elomgation properties but very low shear strength, and gaps under 0.003 put the material into shear. Gaps under 0.003" should utilize PST [ Pipe Sealant w/Teflon ]. Remember you can't be too clean only too dirty when using these materials.
Regards, Bob
G
Bob,
The auto parts store shure oversold the RTV to the DPO.
What a mess! Thanks for the info.
jv
G
Walter,
I used a mityvac today for the first time. twenty minutes tops and i was done! Im sold! I was still pulling some bubbles through the threads even though I gave them a wrap of teflon tape. The brakes are nice and firm though. The vac worked so quick I had time to flush the clutch line of its old fluid also. Its a great little tool!
jv
B General Tech Fuel and teflon tape Triumph 10
steveg Teflon tape - another use Austin Healey 1
Baz Teflon tape on hydraulic lines? MG 7
A Teflon Tape on oil & fuel lines MG 12
NutmegCT Gasoline resistant sealing tape? Restoration & Tools 3
JPSmit Wire Harness tape question Restoration & Tools 3
NutmegCT amalgamating tape? Restoration & Tools 15
drooartz Off Topic Okay, this is a bit classier than the duct tape MG 4
DanLewis Illuminating gauges with Electroluminescent tape Spridgets 24
Darrell_Walker Rescue Tape -- I like it! Triumph 6
TR6oldtimer Looking for a source for Dry Vinyl Harness tape Triumph 5
T Correct way to tape off unneeded wires Triumph 13
bigjones How to use non-adhesive wiring harness tape Spridgets 2
H Harness Tape MG 1
PatGalvin TR2/3/3A TR3 Leaf Spring Rebuild - low friction tape? Triumph 9
JPSmit Not cars but - Duct Tape! Restoration & Tools 3
G Wire Wheel Question: PVC Tape Triumph 19
lbc_newbie 1275 Midget, Sprite Timing Tape Kit Spridgets 2
martx-5 Cloth Insulation Tape Triumph 4
M SCCA Tom Patton race VHS tape[2001] Sunbeam (Rootes) 1
regularman Masking tape question Spridgets 26
GregW Still got those tape measures handy? Austin Healey 5
GregW Anyone have a tape measure handy? Austin Healey 14
H Geoff Healey @ Encounter 1979 - 8trac tape Austin Healey 9
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
K TR2/3/3A Another brake bleed question....... Triumph 17
WHT Remote Clutch Slave Cylinder Bleed Extension Austin Healey 11
bugedd Bench bleed tips Spridgets 14
W TR4/4A Hydralic bleed Triumph 4
G Brake/clutch resevoid replaced do I have to bleed the system Austin Healey 9
Jim_Gruber Did my clutch just bleed itself? Spridgets 11
K TR4/4A Hey CJD...gravity bleed clutch MC and slave? Triumph 6
T TR2/3/3A Bench Bleed Girling Master Cylinder Triumph 2
princetn1 MGB Clutch Bleed MG 3
M General MG Midget clutch bleed - engine out MG 3
trotti Access to the clutch slave cylinder bleed screw Austin Healey 41
AngliaGT 1275 - Just HOW Do I Bleed the Slave Cylinder? Spridgets 4
T TR2/3/3A Only women bleed Triumph 8
K TR2/3/3A Clutch bleed using"gravity bleed" method? Triumph 4
M Bn-2 Windshield Seal Paint Bleed Austin Healey 8
jlaird Brake bleed niples Spridgets 34
K TR2/3/3A TR3A with TR6 trans Clutch Bleed Issue Resolved. Triumph 6
K TR2/3/3A TR3A Clutch Slave Bleed Issue? Triumph 8
D BN2 master cylinder bleed Austin Healey 2
B Bleed Screws Spridgets 2
bugedd Brake bleed question Spridgets 9
bugedd Brake bleed screws Spridgets 6
nevets How to clean a E Z Bleed ? Restoration & Tools 11
K TR2/3/3A TR3 Clutch master and slave bleed issues? Triumph 5
John_Mc Bench bleed slave cylinder? Triumph 4
