Hi Everyone, had an interesting stopping experience today while traveling at 70 mph with a need for a quick stop. The brakes activated and the car swirved right as a result of poor braking on the front left disc brake.
I un tightened the brake bleed screw to test the brake fluid flow rate. There continued to be extreme resistance, and low fluid flow rate out of the bleed screw. This is compared with my brake bleeding experience on the remaining three wheels.
As a check, I removed the small steel brake line running to the caliper to observe the brake fluid flow rate befor the caliper. This checked out fine with lots of fluid flow.
Can someone suggest, what might be causing or a fix to the unusual flow resistance in the caliper?
Cheers!
- Andrew - /ubbthreads/images/graemlins/shocked.gif
Cheers!
