glemon
I have got the brakes hooked up in my TR250, new hoses, new rear cylinders, rebuilt calipers, some but not all new brake lines. New master cylinder.
I can't get fluid through either end, TR250, dual circuit (front and rear) brakes, with servo. Have tried doing the front first, back first, both. even tried loosening the pipes at the master cylinder and nothing came out, do I have a bad M/C maybe, I may have to drain the fluid out, test the lines etc.
M/C is Lucas made and new, I just took it out of the box and put it one, should I have done something more with it?
