Just had a BT7 Tri Carb engine rebuilt & while setting the Valve Lash, noticed one of the Rocker Arms beside the Oil Return Line had the upper Bleed Hole covered by a weld. Was this typical from factory, or has is this a modification that someone else has done? Not sure for what reason.
