TR4/4A 1.5 in outside diameter rocker cover pipe
Twit
Member
I'm reassembling a TR4 and have run into an odd issue. The outside diameter of the oil filler pipe is 1.5 inch but the breather that came with the car(new) and the one I got from Moss both have inside diameter of 1 3/8 inch.
most everything that came with this car is NOS but maybe not 1961.
So I'm wondering did any year have a 1.5 inch OD oil filler pipe that maybe I can order a breather from?
thanks Dave
bobhustead
I had the same problem when I got my cover back from the chromer. I had to hole saw out the bottom plate, make a new one with a bigger hole, and weld (or maybe pop rivet, don't recall clearly) the new plate onto the remaining edge of the old bottom plate.
Have fun.
Bob
Twit
Twit
Member
I don't think I'm up to modifying the breather. I don't have a machine shop.
I can source a chrome aftermarket one with 1.5 inch ID so I'll probably go that route. But thanks for the advise
dave
Twit
Twit
Member
My buddy has a metal lathe and managed to take enough off the inside that it now fits! Luckily I had 2 as the first one didn't survive.
GTP1960 Nice Rambler outside Rock Hill, SC Other Cars 2
J Replace the outside skin on a cargo trailer??? Restoration & Tools 0
J Outside door handle opens but not inside Austin Healey 2
jsfbond GT6 Outside Triumph 4
P Outside door handle Triumph 1
CZ_Dave MGB The MGB's outside MG 3
Brinkerhoff Covers , whats best for outside storage? Restoration & Tools 3
T outside car covers question? Spridgets 2
S XKE 1970 Series II OTS Outside Mirror Jaguar 3
D replace outside door handle Jaguar 4
walshja it's cold outside Spridgets 110
tony barnhill SSsnake's Outside... MG 11
Steve Spotted outside my office today Other Cars 18
jhorton3 20W/50 In Gearbox When It's 100 Degrees Outside Spridgets 2
jlaird Ok, someone outside Spridgets 0
B Fitting the spare wheel on the outside of a BJ8 Austin Healey 10
F Outside mirrors Spridgets 8
P Pin for lock cover on outside door handle Sunbeam (Rootes) 6
SNClocks Master Cylinder Bore Diameter Spridgets 0
BN6_2197 BN6 Pulley Diameter Austin Healey 3
L Tyre diameter less than 680mm but bigger than 640mm, any ideas? Austin Healey 11
K Diameter of Washer Bottle Hole in Parcel Tray Austin Healey 4
Rhodyspit75 Generator pulley diameter Spridgets 2
R TR2/3/3A Clutch Diameter 1957 TR-3 Triumph 1
Foura TR4/4A Universal joint diameter Triumph 9
C Smaller diameter steering wheel - that looks like stock? Austin Healey 16
Geo Hahn TR6 Alternator Shaft Diameter Triumph 6
Sarastro T-Series TD connecting rod big end diameter MG 4
Z BN1 Tyre Diameter Austin Healey 8
Westfield_XI Master cylinder diameter for big brakes Spridgets 23
PatGalvin TR2/3/3A Steering Wheel Diameter with R&P Steering, TR3A Triumph 9
RickB MG Rostyle cap diameter? Spridgets 14
RickB MGB MGB Rostyle cap diameter? MG 0
Bremer Trunnion pin diameter Triumph 3
R Magically increasing bearing diameter Triumph 20
T Fuel line internal diameter Spridgets 5
TexasSprite Inner Brake Drum Diameter? Spridgets 6
healeyboz Gen pulley diameter Spridgets 20
BritCarFan 180mm or 190mm clutch plate diameter? British Motor Corp 1
J clutch master cylinder bore diameter? Triumph 1
Brosky TR6 Diameter of crankshaft pulley on TR6 Triumph 17
T overdrive check ball diameter MG 3
N TR6 Inside diameter for TR6 rear brake drums Triumph 6
S steering wheel diameter Austin Healey 7
T Servo Hose Diameter? Triumph 7
Woodie air filter diameter Spridgets 0
E HS4 SU carb inlet diameter? MG 15
1 Found a picture, q. regarding wheel diameter MG 7
1 MGB Steering wheel diameter? 74 MGB MG 13
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
