TR6 Inside diameter for TR6 rear brake drums
Norton47
Hi
Another question. Previous owner informed me one rear drum was over machined for inside diameter.
I have spotted some used ones that measure 9.042 and 9.048 inches. What is the max inside diameter drums can be machined to?
Thanks
bobh
Some drums have the max ID stamped on the lip. I'm not sure about the TR6 drums. Have you considered new drums? Maybe even finned aluminum?
crj7driver
I looked through my manuals and didn't find anything regarding minimum thickness, just says drum diamter 9 inches
.04 inches is pretty small so you are probably ok
N
Norton47
Thanks, I finally found the drum I.D. in the manual and it says 9". So .04 over is minimum wear to me. Should be able to do a clean up turn without any problems.
Got to watch the budget, but safety first.
Thanks again
TR6oldtimer
I had an opportunity to remove the rear wheels of my 73 TR6. Cast into the drum was the statement that the maximum drum diameter is 9.04 inches....
Hope this helps
N
Norton47
Well thats not good news. I was wanting to use those used drums. That means that the drums can only wear slightly over 1/32nd of an inch in diameter. Man that's not much is it.
Bummer. New drums I guess now.
Thanks
N
Norton47
More info, or how not to do things.
Both local brake shops have a listing that says for 1975 (only listing for Triumph TR6) a 9.050 drum is throw away. One of mine is 9.028 and one is 9.090. PO was right, one is oversized.
The drums state that max diameter is 9.040 with minimum brake lining of .060.
Anyone know what new drums are for inside diameter?
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
T TR2/3/3A rings inside bevel Triumph 2
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
Chuck9482912 Letters Cast Inside Engine Block Austin Healey 0
luke44 TR2/3/3A TR3 inside the tires track dimension Triumph 5
tr6nitjulius Oil flow view inside operating engine Other Cars 4
D What's inside the gas tank?? Spridgets 13
C Inside Door Handle Austin Healey 5
J Flaking Paint Inside Differential Austin Healey 6
S TR2/3/3A rubber seal go towards the inside of the trunk Triumph 3
FlyingCat Spitfire Inside door handle Triumph 2
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
L 100 ID plate inside cockpit Austin Healey 10
G TR4/4A Inside Windscreen Capping Triumph 6
T Frame: Inside Treatment? Austin Healey 8
DornTRoriginal TR2/3/3A Water Inside the Engine Triumph 11
DornTRoriginal TR2/3/3A Water Inside the Engine Triumph 4
RickB MGB Rain water getting inside behind dash MG 17
J BJ8 Inside Top Door Rails-How Attach? Austin Healey 6
M TR4/4A Position of wiring loom inside the trunk/boot area. ? Triumph 3
max71 MGB Here's what the inside of a MGB mechanical gauge looks like MG 0
M BT7 Inside Threshold Plates Austin Healey 1
B Replacement of Small Black Wire inside Distributor Austin Healey 15
Jim_Gruber Painting inside a BE Boot Spridgets 8
Simmo MGB Have you ever tried removing the spring clip on the Keylock from inside the door MG 0
J Outside door handle opens but not inside Austin Healey 2
BoyRacer thermal barrier on inside of firewall Austin Healey 6
D Inside the frame rails Austin Healey 14
A TR2/3/3A TR-3A post 60K inside trunk latch photo Triumph 4
K Rough patch inside bore of SU? Triumph 2
P Odometer Finger Prints inside glass Triumph 9
T TR2/3/3A Peak inside the TR3 sill Triumph 8
R fuel tank cap., anything inside displacing volume? Spridgets 3
Patrick67BJ8 Painting inside of block with Glyptal-need advice Austin Healey 10
H inside of wings question Austin Healey 7
arizonamike TR5/TR250 TR250 Inside Rear View Mirror Mount. Triumph 2
wangdango inside of body panels? Austin Healey 10
TraceZ Our sprite is ALIVE - video inside!! Spridgets 7
M Help - inside my distributor Austin Healey 5
H filters inside of BJ air cleaner? Austin Healey 24
AUSMHLY Inside the car Blind Spot Mirror - MacGyvers back! Austin Healey 61
K TR4/4A Exterior of TR4 gas tank...inside OK Triumph 3
I Source for ribbed material for inside bugeye door? Spridgets 5
M Spitfire RARE BL Spitfire parts catalog see inside Triumph 0
T TR2/3/3A TR3 inside door linkage Triumph 8
eschneider help - points / contacts inside wiper motor ?????? Triumph 9
aeronca65t inside pass Spridgets 9
livinginthepast BE bodywork question - inside/fwd hood brace[?] Spridgets 17
