filters inside of BJ air cleaner?
Healey_Z
What type and where can the filter be purchased that goes in the BJ air cleaner?
Keoke
If the filter material inside the stock filter is missing it would be best to replace the entire filter unit.--Fwiw--Keoke
H
Healey_Z
What I am asking is if there is a filter material that is replaceable?
bob hughes
The proprietary air filters do not need the filter material replacing. - They are a welded shut unit and it would be difficult to open them and retain their original finish.
If you are absolutely desparate, and heck bent on changing the filter media, ( I can't think why ) then I suppose you could resort to using metal pan scrubbers - but I would not recommend it.
These filters should be washed out in paraffin if they are clogged up.
:cheers:
Bob
elrey
Note to Americans; the British folk call what we know as kerosene, parraffin. Bob is referring to kerosene.
richberman
elrey,
Thanks for that translation. I was wondering how the wax candle kit I have could be used for cleaning my air filters. :wink:
rich
Legal Bill
Actually, if you are a member of the Austin Healey Club of America and get Healey Marque magazine, you will see that there was an article in last month's edition about how a person with a ton of time on his or her hands can open up some of the BJ filter housings and replace the factory mesh with filter material from K & N. It is not for the feint hearted as it requires welding, grinding and other sorts of metal work.
H
Healey_Z
Ok got it. I have to say that I have not seen an air cleaner without a replaceable element before. It would seem to make sense that they would need to be cleaned regularly or they aren't filtering much.
Legal Bill
Healey Z, if you think about some of the modern performance filters like K&N, it really isn't a bad idea. The K&N filters are also lifetime filters that require cleaning and oiling periodically.
BobFrisby
Member
I agree that K&Ns are a good modern alternative, but opinions on them are so heated that such discussions have been banned from the e-type forum! You'll note that the ads talk about airflow, not filtration effectiveness. Paper filters do filter a little better, but only at very fine (micron-scale) particle sizes.
The originals are not remotely as effective, but you probably won't be doing much harm by keeping them if you want. This is assumes that the car will only get limited driving, and in favorable conditions. Just clean them in any mild solvent, let them dry, and re-oil with filter oil (K&N has some --). Filter oil is extra-sticky.
The old standard air cleaners (pre '60s) were the oil bath type, which did not have a replaceable element.
When I purchased my Healey 10 years ago, the factory filters were covered with a thin foam sheet backed with a white cloth material. They were held onto each filter with a large band like the hose clamps. I drove a year with them on and then checked them by holding them to the light. There was little, if any, dust and dirt. (They were hand washable). I was told on this forum that it probably inhibited the air flow. I have not noticed any difference when the were removed. I do feel better knowing that there wasn't that much junk sucked into the carbs.
Keoke
If the filter is dirty:
You can clean it up like new by soaking it in parts dip and then flush it out with water.Mask ff the top scree and repaint it in a color of your choice.
If you desire to replace what you have shown then any of the parts houses listed on this forum can sell you one.
Legal Bill
I did not mean to recommend K&N as a substitute for the stock system. I was only pointing out that the idea of a lifetime washable filter is not a bad idea nad is used in modern performance filters like K&N.
bob hughes
:crazyeyes:
<span style="color: #FF0000">Note to Americans; the British folk call what we know as kerosene, parraffin. Bob is referring to kerosene.
</span>
Gosh, thanks for clearing that up Elrey.
On another note, I have put my stock filters aside and I am using air rams - trumpets or venturis - what ever you guys over there call them. They are equiped with a mesh over the tops that keep the rocks out, anything else that passes gets vapourised - I hope.
Available from Burlen
:cheers:
Bob
Keoke
In tried that TH< and my Healey got sick to death.
OH while I'm here watch out for the brown bears--Keoke-- :laugh:
We have black bears. They only look brown. There have been 7 bear break-ins on out block in the last two months. We have been lucky. Must be all the oil spots in the drive way that the don't like (or my wife's cooking).
When you are in a Healey, you are below their chin level. We have had several encounter while driving. They aren't interested in us. Not even a "nice car" or paws up.
elrey
Note to British folk; We call them velocity stacks or air horns. :wink:
Keoke
wELL THE NEWS SAYS THEY JUST STOLE ONE DROVE IT OFF AND TRASHED IT INSIDE TRYING TO GET OUT.--KEOKE-- :lol:
John Turney
No, the bear stole a Prius. :devilgrin:
M TR4/4A Difference between two Oval Air Filters Triumph 3
K TR2/3/3A Foam air filters for S U's Triumph 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
Writer2022 GT6 Overheating after fitting air filters Triumph 4
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
tahoe healey Cooper Air Filters Austin Healey 7
T Spin-On Oil Filters Austin Healey 19
S TR2/3/3A restore my original air filters Triumph 5
Patrick67BJ8 Water filters Austin Healey 16
N Air filters Austin Healey 5
AUSMHLY Spin-oil filter, which filters? Austin Healey 25
JFS TR2/3/3A Weber Air Filters Triumph 7
D TR6 '74 TR6 Tune up, oil, filters questions Triumph 3
doc50 Wanted H2 Air filters for 73 Midget Spridgets Classified 0
PeterK TR4/4A DCOE air filters Triumph 5
L K&N filters on 100/6 1959 Austin Healey 6
B Welch air filters Austin Healey 5
F What to do with breather pipe as my new air filters have no connection for one? Austin Healey 31
T General Tech NOS Paper Air Filters, Shelf Life Triumph 2
T TR2/3/3A Finally found and fitted paper carb air filters on my TR3 Triumph 28
Steve P. Need help with oil filters Spridgets 1
T TR2/3/3A Question on paper air filters for TR3 Triumph 3
M TR4/4A What modified carby air filters to use on my TR4 RHD. Triumph 19
T TR2/3/3A How can I bend TR4 air filters to keep them from hitting fender on TR3A? Triumph 1
PatGalvin TR2/3/3A TR3A After Market Air Filters? Triumph 31
Gearhead_Garage Big Healey Air Filters Austin Healey 22
dcoplan Possible to adapt K&N 1-1/4" air filters to 1-1/8" carbs? Spridgets 14
andrea Azir filters Austin Healey 5
Lin K&N Air Filters for SU HD6 carbs Austin Healey 14
D TR6 Air filters Triumph 2
S Best air cleaners/ filters for street Spridgets 8
Zitch TR4/4A Can I use these Paper filters on my 63 tr4 Triumph 2
G K&N air filters for 1967 BJ8 Austin Healey 6
B oil filters Spridgets 7
fad64b TR2/3/3A TR3 Air Filters Triumph 7
J Spin On Oil Filters Triumph 5
A Anyone have air filters to sell? Triumph 5
A TR2/3/3A What air filters for '59 TR3? Triumph 17
Boink Fuel filters... locations, types... Spridgets 8
S Spitfire Spitfire Fuel line filters Triumph 7
scoutll A Series Spin On Oil filters?? Spridgets 8
I Stock bugeye air filters Spridgets 9
K SU Carb Mix...Air filters on? Triumph 4
E Painting stock air filters Austin Healey 7
8 TR4/4A Upgrade Air Filters for Stromberg TR4A Triumph 6
