SU Carb Mix...Air filters on?
karls59tr
Bronze
I've got the carbs pretty well set up. when I install the air filters do I go one flat lean or one flat rich to compensate for the foam restriction?
TR4
I too am setting my carbs (strombergs though) and wondered about this. Since the air flow will be slightly restricted by adding the filters, won't the fuel be picked up at the same restricted amount so no change would be needed? I had planned to use the handy lift pins on my carbs to see if adding the filters changes anything.
Roger
Bronze
My observation with SUs and Strombergs is that air filters slightly richen the mixture. The slight obstruction they provide increases the depression inthe carb, causing more piston lift but without corresponding increase in airflow.
I'm not sure I can 100% reconcile the theory, but I will point out that Keihin, with their CD carbs based on SU-type principles, used to use flap-valve stranglers for starting.
poolboy
We don't have a lot of diagnostic tools available to us to determine the fuel air mixture that our carbs provide under the combined variety of driving conditions we encounter. Idle, acceleration, deceleration, cruising are all conditions supposedly compensated for basically with an air valve and and a tapered metering needle.
Lift the air valve, works pretty good, if done correctly, but I suspect most hold the air valve up too high or too long while deciding
I've come to regard reading the spark plugs after returning from your average drive is about as good as it gets for all practical purposes.
TR3driver
Great Pumpkin - R.I.P
FWIW I agree with your theory, Roger. Any restriction to air flow acts just like a conventional flap choke (on a fixed venturi carb). It increases the depression 'seen' by the fuel jet, and hence the fuel flow for a given air flow (meaning a richer mixture). One way to compensate would be to vent the float bowl to the inside of the filter (which is exactly what the later 'emissions' carbs do, and partly why they do it).
But my paper filters don't seem to present enough restriction at idle to make a noticeable difference. I get the same results with them on or off. If your filters are offering a significant amount of resistance at idle, then what are they costing you in full throttle, redline power (where the airflow may be 100 times greater) ?
I did some experiments once with the O2 sensor from a newer car mounted in my TR3A exhaust manifold. The results were somewhat surprising, in that the meter would swing from one extreme to the other with the slightest change in throttle. Trying to tune the carbs to be mid-scale (theoretically just enough air to burn the amount of fuel completely) under cruise conditions was both frustrating, and counter-productive. The car ran better with the "lift the piston" method.
But I still hope to pick up a "wide band" exhaust analyzer some day, and see what I can figure out with that. With gas projected to be $5/gallon by summer, it could easily pay for itself in just a few years.
T FYI - Carb cleaner and IBM laptops don't mix Triumph 5
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
E MGB SU CARB OIL 1965 mgb MG 3
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
D Tri carb: order of installation question. Austin Healey 5
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
E MGB SU carb air cleaners MG 10
Healey Nut Tri-Carb Project Austin Healey 213
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
tahoe healey Dumb carb question Austin Healey 23
jfarris TR2/3/3A Happy with my Paltech Carb rebuild Triumph 8
2 TR2/3/3A SU carb. Acts like an expansion valve ! Triumph 10
dbenichou289 TR2/3/3A SU carb linkages Triumph 2
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
O HD8 carb on Healey 3000 Austin Healey 62
dbenichou289 TR2/3/3A Carb Sealing Ring Triumph 6
R TR2/3/3A Carb throttle return spring tension Triumph 2
