TR2/3/3A Weber Air Filters
JFS
Bronze
The tallest filter that will fit my TR3 is 2 1/4". The shortest ram/stack is 1". Will a K&N 4 1/2 X 7 oval 2 1/4" with 1" stack allow enough air for Weber DCOE 40s? The filter would have closed front and back.
M_Pied_Lourd
Tybalt
I watched your video, if it makes you feel any better, I had the grind some of the retainer tabs on 40 DCOEs, it's not just because you were trying to fit them to 42s.
The other thing as you mentioned, the ram stacks position and hold the auxiliary venturi on the 38, 40 and 42 DCOE so at the very least the sleeve part of the stack that sticks into the carb body between it and the auxiliary venturi needs to be in place if one were to decide to just lop off the stack above the ring for the retainer tab, not that I'm recommending doing so. Those APT 16mm stacks are the only ones that I know of right of hand that work with the short K&N oval filter set up.
JFS
JFS
Bronze
Tybalt, will the 45 K&N filter backing plate bolt up to the 40 DCOE? Do the mounting holes match?
Tybalt
They should if I'm recalling the Weber DCOx series dimensions correctly ( I'm out of town and don't have access to all my reference and technical information). Besides the guys at APT say in that listing to use the 45 DCOE filter with those stubby ram stacks. In my dealings with APT, I just can't imagine them saying that if they would not fit but you could always contact them for clarification. I already had filters for the 40 DCOE sitting on the shelf and didn't feel like ordering up another set of filters, so I opened up the holes in the base plate. Since these were going on a TR6, that was six holes to open up and let me assure that while it is definitely "doable," it was a rather tedious task that took longer than expected.
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
T looking for simple Weber Wisdom, and angled air horns Spridgets 1
W Weber/stromberg air cleaners Jaguar 3
R k&n air filter p/n for weber dgv on 1500 midget? Spridgets 7
R weber 32/36 dgv, selecting jets, air correctors? Spridgets 15
Stewart Oil for weber air filter MG 4
S Weber manifold-air leak MG 2
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
S Weber carb set Other British Cars 7
TomMull Wanted Weber 40 DCOE 18 Other British Classifieds 1
TomMull Weber Carburetors Lotus 18
C MGB More Weber help needed MG 27
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
A Spitfire Weber Carburetor Triumph 0
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
steveg Weber balancer on HD8s Austin Healey 11
H General Tech Tripple Weber Swan Neck Manifolds for Triumph? Triumph 1
G Triple Weber DCNFs on 280i V6? TVR 1
P For Sale Weber carb/intake, header Spridgets Classified 2
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
H Triple Weber 45's Tipp? Austin Healey 2
R Pedal box clearance mod for triple Weber clearance Austin Healey 7
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
toysrrus TR6 Weber DCO45 cost? Triumph 6
bugedd Weber intake manifold Spridgets 4
T Understanding Weber DCOE identifiers? Spridgets 0
T Problems disassembling a Weber side-draft DCOE Spridgets 2
T Identifying vintage of a Weber DCOE Spridgets 4
T Weber for a 1275 cc engine? Spridgets 6
M_Pied_Lourd TR2/3/3A Weber Carb Installation Question Triumph 13
drooartz Leaning out/tuning a Weber on a 1275 Spridgets 20
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
krswen Comparing Weber kits .... advice sought Jaguar 4
DanLewis Weber 40DCOE - Does it need a check valve in the fuel supply line? Spridgets 4
DanLewis Side draft Weber and smell of gasoline? Spridgets 3
bthompson What fuel pressure does a Weber DGV like? Spridgets 2
N Spitfire Weber Carburetor Upgrade - 77 Spitfire Triumph 9
B Weber DGV Spridgets 2
TomChar Weber MCHH carbs Triumph 23
A TR6 Triumph TR6 Triple Weber carbs Triumph 9
