twas_brillig
I've got a 40DCOE that I cannot get the choke out of (the last removable piece to slide out of the body). One side (choke and venturi) came out no problem but the other side (venturi no problem) is proving to be impossible.
I've removed any and all securing parts; soaked it in penetrating fluid; tried tapping it out past the butterfly; built an extractor (two large flat washers stacked on the butterfly side, with a threaded rod passing through them and held in place with a nut; the other end comes out the intake of the Weber and through a chunk of angle iron with a nut to hold the assembly together and to apply a force to pull the choke out). No luck at all.
I want to change the chokes etc. etc. and install on our 1275, but things are definitely not going well.
Wisdom, anyone? Thanks, Doug
