TR6 Gas pump problems.
ichthos
I put in a VB fuel pump yesterday. Today whenI got to work and went out on break, there was gas leaking quickly from the top of the pump. The top gasket had swelled and pulled away from the top. It appears the top gasket is not gasoline proof. Anyone else has this problem?
Kevin
M_Pied_Lourd
Yes, I've had that happen. Do you have your old pump? Use the gasket from that if you do.
Cheers
Tush
I
ichthos
Thanks for the advice. At least I got home. VB is sending out a new gasket. I will place it in gasoline to see if it holds up this time.
M_Pied_Lourd
Also, if you happen to have an old original pump kicking around, steel the brass screen from the inside and replace the crappy plastic one inside the reproduction pump. I find the plastic screen tends to deform and disintegrate in the 'new' gas.
Cheers
Tush
DNK
Kevin, great to see you still driving it.
As Tush says...
There is a very good company that sells all the "right" stuff to rebuild your old one.
TomChar
Do you folks recommend installing a pre-pump inline fuel filter? Just a thought to keep that new pump in good condition..
M_Pied_Lourd
Hi Tom,
Yes, for sure. Many of us also have an inline shut off valve installed as well.
Cheers
Tush
poolboy
Absolutely. I even know a couple of people who have yet another filter between the pump and the carbs.
longbridgehealey Fuel pump racing, no gas Austin Healey 26
J Gas pump auto shut off question Austin Healey 2
longbridgehealey Gas pump for 1275 Spridgets 20
M TR4/4A TR4 Optimal Compression - 91 Octane Pump Gas Triumph 13
J New SU Fuel Pump - Gas leaking out of carb vents Austin Healey 24
rlich8 Fuel Pump & Gas Line fittings Triumph 5
Walk New Fuel Pump & Rebuild Carb - No Gas in Between! MG 21
Westfield_XI Maximum compression ratio for A-series on pump gas Spridgets 14
Celtic 77 MGB LeMans Gas filler MG 10
mctriumph General TR NEVER start a car with stale gas Triumph 0
TomMull GT6 Gas Tank Outlet Triumph 0
B TR6 Gas on spark plugs Triumph 7
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
edkap2002 TR6 gas tank sounds Triumph 8
MGTF1250Dave T-Series TF Gas Tank MG 6
B General MG 77 MIDGET Gas tank sending unit MG 1
G Wanted gas tank dip stick for mgtf 1555 MG Classifieds 1
Celtic 77 MGB Pessimistic Gas gague MG 10
B gas leak underneath the carburetor Restoration & Tools 2
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
P MGB Mgb gas tank cap MG 7
LAW75 Concours: Original Gas Hose Austin Healey 12
LAW75 Gas Odor Elimination Austin Healey 3
B TR4/4A GAS TANK FELT Triumph 14
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
edkap2002 TR6 gas smell Triumph 8
R TR2/3/3A Gas pedal pad for TR-2 Triumph 3
B Damaged threads in the gas tank Austin Healey 7
BierRunner TR6 TR6 Gas Pedal Triumph 4
Jim_Stevens Off Topic Ethanol-free gas link Triumph 1
J TR2/3/3A TR3 gas tank mystery Triumph 5
Rob Glasgow New Gas Tank Austin Healey 8
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
B TR4/4A Gas Tank color? Triumph 4
B BE vs. Later Model Gas tanks Spridgets 2
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
JPSmit Fuel line - gas tank question Restoration & Tools 5
Ripper01 SOLD-TR6 Gas Tank Triumph Classifieds 3
A Wanted Gas tank for TR6 Triumph Classifieds 5
J For Sale Triumph Tr 2/3 Gas Pedal Triumph Classifieds 1
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
D What's inside the gas tank?? Spridgets 13
C TR2/3/3A Gas Line Triumph 11
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
S TR2/3/3A TR3 gas filler cap Triumph 1
J TR2/3/3A TR3A gas tank repair Triumph 7
Rut MGB Running out of gas symptoms MG 21
T TR2/3/3A TR3A Gas Cap Triumph 15
D Gas Pedal Pad Jaguar 7
K For Sale TR3 Gas Cap Assembly Triumph Classifieds 0
