Weber/stromberg air cleaners
wrenchranch
Greg Childs here of Montana: I have an 69 Series ll with the weber/strombergs. I have replacedthe original air cleaner system with an aftermarket filters I am currently using two foam type from XK's but suspect they are restricting breathing. Does anyone have a suggestion for a better aftermarket setup? By the way.... XK's does not provide the K&N filters they advertise. Something about they do not fit properly.
LarryK
Check with K&N and see what they say. Try Terry's Jaguar, he races the Jags and may have something that will fit.
Geo Hahn
From a current ebay listing:
The full listing: 69 E-Type on Ebay
No other experience or info, just a link to a pic that may illustrate what works.
SherpaPilot [b][color:#000000]Stromberg vs. Weber[/color][/b] Triumph 14
TR4 Converting from Stromberg to Weber Carbs? Triumph 23
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
S Weber carb set Other British Cars 7
TomMull Wanted Weber 40 DCOE 18 Other British Classifieds 1
TomMull Weber Carburetors Lotus 18
C MGB More Weber help needed MG 27
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
A Spitfire Weber Carburetor Triumph 0
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
steveg Weber balancer on HD8s Austin Healey 11
H General Tech Tripple Weber Swan Neck Manifolds for Triumph? Triumph 1
G Triple Weber DCNFs on 280i V6? TVR 1
P For Sale Weber carb/intake, header Spridgets Classified 2
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
H Triple Weber 45's Tipp? Austin Healey 2
JFS TR2/3/3A Weber Air Filters Triumph 7
R Pedal box clearance mod for triple Weber clearance Austin Healey 7
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
toysrrus TR6 Weber DCO45 cost? Triumph 6
T looking for simple Weber Wisdom, and angled air horns Spridgets 1
bugedd Weber intake manifold Spridgets 4
T Understanding Weber DCOE identifiers? Spridgets 0
T Problems disassembling a Weber side-draft DCOE Spridgets 2
T Identifying vintage of a Weber DCOE Spridgets 4
T Weber for a 1275 cc engine? Spridgets 6
M_Pied_Lourd TR2/3/3A Weber Carb Installation Question Triumph 13
drooartz Leaning out/tuning a Weber on a 1275 Spridgets 20
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
krswen Comparing Weber kits .... advice sought Jaguar 4
DanLewis Weber 40DCOE - Does it need a check valve in the fuel supply line? Spridgets 4
DanLewis Side draft Weber and smell of gasoline? Spridgets 3
bthompson What fuel pressure does a Weber DGV like? Spridgets 2
N Spitfire Weber Carburetor Upgrade - 77 Spitfire Triumph 9
B Weber DGV Spridgets 2
TomChar Weber MCHH carbs Triumph 23
A TR6 Triumph TR6 Triple Weber carbs Triumph 9
Pythias Weber DGAV questions Spridgets 8
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
