TR4/4A Exterior of TR4 gas tank...inside OK
karls59tr
Bronze
Rust got to the top of the tank on the outside to the point where it was pitted but not bad enough where holes are an issue. I wire brushed the area and stabilized the rust with a chemical. Now I would like to skim coat the surface. Any Ideas on what to use.
TR4
POR15 would be one choice. Simple Rustoleum or Eastwoods Rust Encapsulator would be alternative choices.
trrdster2000
Agree, but you should still seal the inside of the tank. It's a two or three step process, Most bike shops carry it around here, but the above mentioned also have one.
Wayne
M TR4/4A Where to buy replacement TR4 exterior door handles? Triumph 1
NutmegCT Exterior wood finish Restoration & Tools 21
Michael Oritt Exterior cover recommendations Austin Healey 7
S LED Exterior Light Upgrade Spridgets 15
H Joan Baex 1961 flat floor--silver exterior--anybody know what IRS sold it for? Jaguar 0
johnrip Wedge TR7 exterior door handle buffer instalation Triumph 3
NutmegCT Exterior paint - rusty spot Restoration & Tools 3
K Cleaning up exterior surface of SU's? Triumph 8
S TR2/3/3A TR3 Exterior Door handles Triumph 4
S Interior/Exterior color choices........help? Jaguar 12
N Exterior and Interior color codes MG 3
angelfj1 TR2/3/3A TR-3A exterior lighting - best source Triumph 4
NutmegCT fuzzy red exterior! Triumph 3
2wrench TR6 Help removing an exterior door lock, '74 TR6 Triumph 1
S Bugeye exterior colors Spridgets 4
M TR2/3/3A TR3 photo - exterior [2nd try] Triumph 3
M TR2/3/3A TR3 photo - exterior Triumph 0
W Exterior Heat Insulation?? Austin Healey 20
P Matching Carnival Red Exterior Paint Sunbeam (Rootes) 2
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
