clutch master cylinder bore diameter?
jackag91
How do I figure out which one I have? Is it the internal bore of the main housing?
I know the car doesn't have the original and I just want to make sure before I order a rebuild kit?
martx-5
Yes. Just measure the inside diameter of the cylinder bore, or the outside diameter of the piston that came out of the bore.
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
D Clutch Master Cylinder Leak Austin Healey 20
angelfj1 Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS Triumph Classifieds 4
angelfj1 TR2/3/3A 59 TR3A Clutch Master Cylinder Failure Triumph 19
D 1965 Alpine Clutch Master Cylinder Sunbeam (Rootes) 0
warwick-steve Final fix for clutch pipe to master cylinder leak?? Austin Healey 13
KVH TR4/4A Clutch Master Cylinder Triumph 3
warwick-steve Clutch master cylinder to fluid reservoir leak Austin Healey 5
Rob Glasgow Clutch Master Cylinder Issue Austin Healey 3
Got_All_4 TR2/3/3A Clutch issue maybe master cylinder Triumph 13
S MGB MGB clutch master cylinder MG 0
M TR6 Which clutch master cylinder for a 71 TR6? Triumph 5
John_Mc TR6 Rebuild or replace Clutch Master Cylinder? Triumph 8
MY66AH Master Cylinder Clutch Rod Spridgets 6
AngliaGT Early '74 Midget - Clutch Master Cylinder Removal Spridgets 7
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
K TR2/3/3A Clutch Master Cylinder "Stop" Bolt.... Triumph 4
R Clutch Master Cylinder Shim Austin Healey 12
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
H master cylinder brake vs mc clutch Austin Healey 14
J T-Series clutch Master cylinder or slave? MG 8
Lukens More clutch / brake master cylinder questions. Triumph 7
Henson80MGB T-Series '80 MGB Clutch Master Cylinder-rebuild or replace MG 10
dondel Clutch Fork movement & Master Cylinder Austin Healey 13
PATR8 New Clutch Master Cylinder Triumph 4
mrv8q TR2/3/3A TR3 Clutch Master Cylinder Triumph 20
T Putting the clutch master cylinder back together Triumph 13
Shinsen774 T-Series Clutch Master Cylinder - The little things can be MG 14
Y BJ8 Clutch Master Cylinder Bleeding Procedure? Austin Healey 7
M Clutch Master Cylinder Cap Spridgets 7
hondo402000 TR6 TR6 clutch master cylinder arrived[not girling] Triumph 5
TRnorwegian Changing clutch master cylinder - peace of cake? Triumph 10
T Clutch master cylinder ? Triumph 5
X T-Series Clutch Master Cylinder Cap MG 2
R T-Series 74 B clutch master cylinder MG 0
I TR6 Correct clutch master cylinder fluid for 69TR6? Triumph 5
C brake & clutch master cylinder question Austin Healey 2
N Clutch Master cylinder, rebuild or not. Triumph 26
G clutch master cylinder rebuild. Spridgets 0
Branson Clutch / Master Cylinder Question Spridgets 1
A Clutch Master Cylinder Line Triumph 3
jerrybny Clutch Master Cylinder Cap Triumph 2
jjbunn T-Series Clutch Master Cylinder - where is it?! MG 3
