Hi folks! I'm back in an MGB again after a long run with assorted Miatas-- I'm lovin' having a B again but just had a clutch failure. Wife and I were doing a neighborhood cruise and I first noticed the clutch didn't release for shifting unless fully depressed. By the time I got back home and pulled in the driveway, I had to no clutch. I did the do the clutchless shifting thing to get the car the rest of the way into the garage (you know, synch the RPM or stop the car in neutral, shift into first and start the car in gear). Anyway, are the symptoms different with MC failure and slave failure? I assumed it was the MC since it failed like another car I had but not sure. Comments?
