Putting the clutch master cylinder back together
tdskip
OK - so here is the documentation on putting the clutch master back together. Please point out any errors so I can correct the steps.
Getting ready to be honed;
Spray the bore with WD40 to help prevent scoring the bore;
I've been coached not to "over" hone the clutch M/C, a little will do;
Wash it out well using tap water;
Dry it out in prep for the rebuild;
Ready for the plunger to be rebuilt now;
T
tdskip
OK - time to start the plunger;
You first have to "unlock" the spring assembly, you do that bu gently lifting up on the tab;
Once you do that you can separate the piston;
You then remove the rubber ring on the pistion
Peel it all the way off
Then push the new one one. The side with the indentation/ring faces back towards the spring like shown here;
T
tdskip
Next is the spring and fittings on the other end;
Pull the "crown" fitting down;
And then peel off the rubber boot. if you look closely you can see how torn up this one was, hence the leaking.
Put the new rubber on
Put the curved washer and crown back on
It should look like this when it is ready to rejoined with the piston
Guide the spring up over the end of the piston and then press the tab back down securely;
It is now ready to be reinstalled!
TR3driver
Great Pumpkin - R.I.P
A little clean brake fluid will help lubricate the process.
TR3driver
I'd call that a "seal" rather than a boot. Normally, it's easier to remove/install over the small end
Overall, it all looks good to me. Two bits that perhaps could be clearer : sliding the link (inside the spring) to one side to remove it from the cup-shaped clip, and being sure the link fits into the center of the piston when reassembling the clip onto the piston.
Good work, Tom!
TR4nut
Re: Putting the clutch master cylinder back togeth
Tom-
Excellent stuff here - any thoughts of saving it to the Wiki for future use?
Randy
T
tdskip
TR4nut said:
Tom-
Randy
That is what I was thinking Randy. I've learned so much from everyone here so when I have to do something that I haven't seen documented (or with as much focus on newbies like me) I try to write it up. The Buckeye Triumph site does have a very good write up, but I thought that some additional pictures of the details might help.
I have fooled around with the wiki yet, can I largely just cut and paste?
R
RonMacPherson
One thing, on reinstalling the clip, it's a good idea to make sure you install it properly. There will be a bevel edge and a sharp corner edge. The sharp corner needs to go in properly.
TR3driver
Photos seem a little dark ...
T
tdskip
Ahola Ron - good point. Thanks.
Randall - My camera doesn't like the white paper towell in the background, will try a different surface next time.
TR3driver
Tom, Irfanview is really cheap (free), and does a good job at fixing things like that. https://www.irfanview.com/ The photo I posted above is a copy of yours, with just a quick crop and shift-U.
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
algot1901 Putting the doors on Other British Cars 11
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
69MGC MGC Putting a 12v battery in the trunk MG 10
R TR2/3/3A Putting windshield back together Triumph 13
T TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels Triumph 4
B General TR Putting the rebuilt gear box back in the TR6 Triumph 1
F Chocking the rear wheels and putting in gear when jacking up the front Austin Healey 8
2billydavies TR2/3/3A looking for suggestions on putting engine back in Triumph 17
S Putting my 68 on the road. Spridgets 12
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
S TR2/3/3A putting the sleeves into the block Triumph 7
K TR2/3/3A Putting an XKE engine in a TR3? Triumph 10
K TR2/3/3A Putting traction bars on a TR3? Triumph 3
T TR5/TR250 Downside to putting TR250 fan on TR3 Triumph 13
Trevor Jessie Putting a 1275 in a rubber Bumper car Spridgets 17
K TR4/4A Putting H6 SU's on a TR4A intake manifold. Triumph 1
B TR6 Putting a 205 75 tire on a tr6 Triumph 4
B TR6 Putting a Tr4 top on a Tr6 Triumph 14
G Where you 6 guys putting fuel pumps? Triumph 10
J Putting the IRS on stands ??? Triumph 5
J Putting BE dash together from box of random parts- Spridgets 12
tomshobby TR6 putting scuttle door on 76 TR6 Triumph 9
J AH 1962 - Putting on Front Fenders Austin Healey 8
G putting on new top MG 5
T First time putting front hubs on - any tips Triumph 7
doughairfield TR4/4A Putting the motor back in the TR4 Triumph 9
Got_All_4 TR2/3/3A Putting a J type in a TR3A Triumph 14
hondo402000 TR6 TR6 Final Paint pics and Putting it back together Triumph 31
K TR4/4A Putting aTR4 motor and trans in a TR3 Triumph 4
UmmYeahOk Dammit! Quit Putting Holes in My Car!!! Triumph 32
pjsmetana Spitfire Putting the Spit in a car show saturday Triumph 2
liljohnTR250 TR5/TR250 putting new top on TR250 Triumph 7
J Putting my head back together. Triumph 3
Newkie Putting weatherstipping on windscreen MG 11
J putting the diff back together tonight Triumph 2
Thor Putting in 1275 motor into 1500 Midget Spridgets 4
7 Putting the front wheel bearing back together. Triumph 0
L Putting Humpty Dumpty Back Together Again Austin Healey 3
GregW Putting the windshield back together Austin Healey 10
Steve Putting it all back together MG 3
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
