Putting my head back together.
jackag91
I picked my head up this week and it looks like the guy did a great job on regrinding the seats and the valves to match.
I am going to put it back together before my next trip to work on the car.
I just wanted to make sure that I had everything I need.
Head
Waterpump
Temp Sending unit
Valves
Valve springs (they are the dual springs)
Spring retainers
Spring retainer keepers
Besides a gasket set is there anything I am missing. Looking at the parts book, there seems to be a lower collar but I didn't take any off the head when I took it in.
Is this needed or is this something I could do with out.
G
Make darn sure that you have the correct spring pressure for your particular setup. Any good automotive machine shop will have the gadget for properly measuring pressure in various points of closure. I don't have the specs at my finger tips but they are available. You might well need the collars, as well as shims. Mine did. I ran way too little pressure for about 5000 miles till I lost a cam and tappets.
J
jackag91
Thanks Bill
Is the information in the shop manual compatible with afetermarket cams? Or would a different cam effect the required spring height and/or rate?
G
I found the slip that I wrote down my specs on. With the valve seated, I needed 80-90 lbs of pressure and with the valve open with a .400 lift, I had the springs (double) set at 170-180 lbs of pressure. To achieve this, my set of double springs needed the stock lower collar added as well as a shim. Works for me. Before this, just checking the spring set the way they were placed before I lost the cam, the pressures were way, way below this. There is a little lever gadget that any automotive machine shop will have that can check and set these pressures by adding or subtracting shims. I actually bought a brand new set of "high performance" springs from a vendor that he swore would be all I needed by themselves. They were even worse than what I had. I am comfortable with my new setup.
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
algot1901 Putting the doors on Other British Cars 11
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
69MGC MGC Putting a 12v battery in the trunk MG 10
R TR2/3/3A Putting windshield back together Triumph 13
T TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels Triumph 4
B General TR Putting the rebuilt gear box back in the TR6 Triumph 1
F Chocking the rear wheels and putting in gear when jacking up the front Austin Healey 8
2billydavies TR2/3/3A looking for suggestions on putting engine back in Triumph 17
S Putting my 68 on the road. Spridgets 12
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
S TR2/3/3A putting the sleeves into the block Triumph 7
K TR2/3/3A Putting an XKE engine in a TR3? Triumph 10
K TR2/3/3A Putting traction bars on a TR3? Triumph 3
T TR5/TR250 Downside to putting TR250 fan on TR3 Triumph 13
Trevor Jessie Putting a 1275 in a rubber Bumper car Spridgets 17
K TR4/4A Putting H6 SU's on a TR4A intake manifold. Triumph 1
B TR6 Putting a 205 75 tire on a tr6 Triumph 4
B TR6 Putting a Tr4 top on a Tr6 Triumph 14
G Where you 6 guys putting fuel pumps? Triumph 10
J Putting the IRS on stands ??? Triumph 5
J Putting BE dash together from box of random parts- Spridgets 12
tomshobby TR6 putting scuttle door on 76 TR6 Triumph 9
J AH 1962 - Putting on Front Fenders Austin Healey 8
G putting on new top MG 5
T First time putting front hubs on - any tips Triumph 7
doughairfield TR4/4A Putting the motor back in the TR4 Triumph 9
Got_All_4 TR2/3/3A Putting a J type in a TR3A Triumph 14
hondo402000 TR6 TR6 Final Paint pics and Putting it back together Triumph 31
K TR4/4A Putting aTR4 motor and trans in a TR3 Triumph 4
T Putting the clutch master cylinder back together Triumph 13
UmmYeahOk Dammit! Quit Putting Holes in My Car!!! Triumph 32
pjsmetana Spitfire Putting the Spit in a car show saturday Triumph 2
liljohnTR250 TR5/TR250 putting new top on TR250 Triumph 7
Newkie Putting weatherstipping on windscreen MG 11
J putting the diff back together tonight Triumph 2
Thor Putting in 1275 motor into 1500 Midget Spridgets 4
7 Putting the front wheel bearing back together. Triumph 0
L Putting Humpty Dumpty Back Together Again Austin Healey 3
GregW Putting the windshield back together Austin Healey 10
Steve Putting it all back together MG 3
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 5
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
