TR6 putting scuttle door on 76 TR6
tomshobby
I have been collecting the parts so I can install a scuttle vent door on my 76 TR6. I now nearly have everything needed and plan on this project as soon as the snow melts in the spring.
I miss this feature that my TR4 had and will be glad to have that gaping hole uncovered when the trees again drop their litter. Funny how a tree can drop things so it goes right into the scuttle vent.
Anyway, it would be a big help to have a photo of how the lever fits and the pivot location. Thanks.
DougF
Please keep us posted as this is something I'm interested in doing.
BobbyD
tomshobby said:
Thanks Bobby,
Excellent stuff, I had already went through that thread and it has most of what I need. The one thing is how and where the control lever mounts. Including where it comes out for operator access.
Tom........send Lou a PM or an email and I'm sure he'll give you all the answers and pictures you'll need. He's a real good guy and vey helpful.
justin_mercier
I'm converting my 76 TR6 to have the scuttle vent door as well, I've got the pieces I need on order from TRF currently. I'm doing a lot of non-standard stuff to my TR6, and I'm actually planning on removing the heater box and stock internal air ducting entirely, and turning the scuttle intake into more of the equivalent of the footwell air ducts on my TR7 instead. Open the vent, get a cool breeze in the footwell, close it and keep the water / weather out.
justin_mercier
On this same note, has anyone discovered a source for the scuttle vent spring from the earlier models? I can make a pull tab for the vent easy enough, but bending an accurate and fitting hinge/spring would be a pain and probably cheaper to buy if i can find one.
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
algot1901 Putting the doors on Other British Cars 11
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
69MGC MGC Putting a 12v battery in the trunk MG 10
R TR2/3/3A Putting windshield back together Triumph 13
T TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels Triumph 4
B General TR Putting the rebuilt gear box back in the TR6 Triumph 1
F Chocking the rear wheels and putting in gear when jacking up the front Austin Healey 8
2billydavies TR2/3/3A looking for suggestions on putting engine back in Triumph 17
S Putting my 68 on the road. Spridgets 12
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
S TR2/3/3A putting the sleeves into the block Triumph 7
K TR2/3/3A Putting an XKE engine in a TR3? Triumph 10
K TR2/3/3A Putting traction bars on a TR3? Triumph 3
T TR5/TR250 Downside to putting TR250 fan on TR3 Triumph 13
Trevor Jessie Putting a 1275 in a rubber Bumper car Spridgets 17
K TR4/4A Putting H6 SU's on a TR4A intake manifold. Triumph 1
B TR6 Putting a 205 75 tire on a tr6 Triumph 4
B TR6 Putting a Tr4 top on a Tr6 Triumph 14
G Where you 6 guys putting fuel pumps? Triumph 10
J Putting the IRS on stands ??? Triumph 5
J Putting BE dash together from box of random parts- Spridgets 12
J AH 1962 - Putting on Front Fenders Austin Healey 8
G putting on new top MG 5
T First time putting front hubs on - any tips Triumph 7
doughairfield TR4/4A Putting the motor back in the TR4 Triumph 9
Got_All_4 TR2/3/3A Putting a J type in a TR3A Triumph 14
hondo402000 TR6 TR6 Final Paint pics and Putting it back together Triumph 31
K TR4/4A Putting aTR4 motor and trans in a TR3 Triumph 4
T Putting the clutch master cylinder back together Triumph 13
UmmYeahOk Dammit! Quit Putting Holes in My Car!!! Triumph 32
pjsmetana Spitfire Putting the Spit in a car show saturday Triumph 2
liljohnTR250 TR5/TR250 putting new top on TR250 Triumph 7
J Putting my head back together. Triumph 3
Newkie Putting weatherstipping on windscreen MG 11
J putting the diff back together tonight Triumph 2
Thor Putting in 1275 motor into 1500 Midget Spridgets 4
7 Putting the front wheel bearing back together. Triumph 0
L Putting Humpty Dumpty Back Together Again Austin Healey 3
GregW Putting the windshield back together Austin Healey 10
Steve Putting it all back together MG 3
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
B For Sale BaulyCars - Scuttle Vent Cover Triumph Classifieds 0
71TR6 TR2/3/3A TR3A Scuttle Rim Question Triumph 4
F TR2/3/3A starting scuttle repair Triumph 27
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
C TR2/3/3A scuttle vent Triumph 6
steveg Steering column steady brace and scuttle shake? Austin Healey 2
D TR2/3/3A Scuttle uneven on one side Triumph 12
