Putting in 1275 motor into 1500 Midget
Thor
My question is can anyone share their experience or thoughts about replacing their 1500 engine with the 1275?
I have access to a complete 1275 engine bay including transmission, engine, radiator, etc. Doing so would give me drivebiltiy while I can take my time rebuilding the 1500.
Did much change in aspects of the car body that would prohibt me from doing this easily? Also since the 1500 didn't give much performance enhancements over the 1275 do you think I would notice much loss of performance? Certainly there are more enhancements for the 1275 and perhaps I could add some to get an extra boost of power.
Thanks
LeeMcKee
I'm doing the same thing with my 78 midget.
The 1500 is a "good" engine but I think the 1275 may be a better one. The 1500 has a little more torque but the 1275 can rev higher. I've been a Triumph man for many years and I like the 1500 but the 1275 is a more relieable engine. Besides the 1500 has a fatal flaw in that the thrust washer on the end of the crank is cresent shaped and will fall out over time, When it does it will eat out the block and eventally your connecting rods or crank will fail on you. (Normally in a spectaulor way!)
I am planning to run my midget in some vintage races in the future so I HAVE to change over to a 1275 for that but If I didn't have to I would leave the 1500 in her and just stay on top of the engine matinence. There are quite a few mods for the 1500 engine, just venture over to the Triumph spitfire side for a little while and you will see them. Spitfires do pretty well at vintage events so they must be doing something right.
Other than that the transfering of the engines is more or less straight forward. You will need the trans for the 1275 and a new drive shaft. And while your at it the speedo cable is a little different as well as some other bits and pieces. If you don't feel like driving the midget for a few months then it can be done but if your not racing the midget in vintage or if your not trying to give the car a older appearance by removing the rubber battering rams and such then it is not worth it in my opinion. Some people remark that "It's a sin to have a Triumph engine in an MG" But the midget(sprite) was designed by Donald Healey for Austin Motors (of course). So, what you have is an Austin-Healey with MG badges and a Triumph engine. I don't see any thing wrong with that.
/ubbthreads/images/graemlins/driving.gif
Bugeye58
Other than a few bits, like the previously mentioned driveshaft, and a new exhaust, the 1275 is a virtual bolt in.
I think you may be pleasantly surprised at the result.
You may want to find a 3.9 rear gear for it, though.
Jeff
aeronca65t
I'm doing the exact same thing as Lee (and for the exact same reason). I expect it to be pretty straight forward.
If you're into modding the engine, then you will love the switch, there are more 1275 speed goodies available than you can shake a stick at.
Trevor Jessie Putting a 1275 in a rubber Bumper car Spridgets 17
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
algot1901 Putting the doors on Other British Cars 11
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
69MGC MGC Putting a 12v battery in the trunk MG 10
R TR2/3/3A Putting windshield back together Triumph 13
T TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels Triumph 4
B General TR Putting the rebuilt gear box back in the TR6 Triumph 1
F Chocking the rear wheels and putting in gear when jacking up the front Austin Healey 8
2billydavies TR2/3/3A looking for suggestions on putting engine back in Triumph 17
S Putting my 68 on the road. Spridgets 12
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
S TR2/3/3A putting the sleeves into the block Triumph 7
K TR2/3/3A Putting an XKE engine in a TR3? Triumph 10
K TR2/3/3A Putting traction bars on a TR3? Triumph 3
T TR5/TR250 Downside to putting TR250 fan on TR3 Triumph 13
K TR4/4A Putting H6 SU's on a TR4A intake manifold. Triumph 1
B TR6 Putting a 205 75 tire on a tr6 Triumph 4
B TR6 Putting a Tr4 top on a Tr6 Triumph 14
G Where you 6 guys putting fuel pumps? Triumph 10
J Putting the IRS on stands ??? Triumph 5
J Putting BE dash together from box of random parts- Spridgets 12
tomshobby TR6 putting scuttle door on 76 TR6 Triumph 9
J AH 1962 - Putting on Front Fenders Austin Healey 8
G putting on new top MG 5
T First time putting front hubs on - any tips Triumph 7
doughairfield TR4/4A Putting the motor back in the TR4 Triumph 9
Got_All_4 TR2/3/3A Putting a J type in a TR3A Triumph 14
hondo402000 TR6 TR6 Final Paint pics and Putting it back together Triumph 31
K TR4/4A Putting aTR4 motor and trans in a TR3 Triumph 4
T Putting the clutch master cylinder back together Triumph 13
UmmYeahOk Dammit! Quit Putting Holes in My Car!!! Triumph 32
pjsmetana Spitfire Putting the Spit in a car show saturday Triumph 2
liljohnTR250 TR5/TR250 putting new top on TR250 Triumph 7
J Putting my head back together. Triumph 3
Newkie Putting weatherstipping on windscreen MG 11
J putting the diff back together tonight Triumph 2
7 Putting the front wheel bearing back together. Triumph 0
L Putting Humpty Dumpty Back Together Again Austin Healey 3
GregW Putting the windshield back together Austin Healey 10
Steve Putting it all back together MG 3
CARSINC WANTED: 1275 Engine Spridgets 0
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
D A distributer question on the 1275 engine. Spridgets 7
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
