brake & clutch master cylinder question
carlivar
Member
I've got my clutch & brake master cylinders out right now. 1966 BJ8.
The rods that go from the pedal linkage to the cylinders are different... what surprised me is that my brake cylinder's rod has threads on it. I guess it's for pedal adjustment.
I would think the clutch rod would be adjustable, not the brake... did a previous owner switch these? They seem a bit similar otherwise.
Could someone confirm which rod is supposed to be threaded?
Thanks!
vette
I'm not sure but I think both of mine are the same and they are straight and smoothe, no adjustment. If you bleed everything up snug, you don't need an adjustment. Well maybe for pedal height, i've never had to worry about that. Did you find a shim between the master and the firewall bulkhead. I had just one, couldn't remember which cylinder it was under, so I took a guess. had no effect. According to Keoke ( wonder where he is ) it's not needed.
C
carlivar
Member
Found the answer on the healeys mailing list... the threaded rod is indeed for the brakes... to make the pedal same height as the clutch (which is not adjustable). Makes sense!
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
M_Pied_Lourd TR2/3/3A Brake and Clutch Master Pushrod Question Triumph 4
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
H master cylinder brake vs mc clutch Austin Healey 14
Lukens More clutch / brake master cylinder questions. Triumph 7
R TR2/3/3A TR 3a brake/clutch master cylinders/pedal movement Triumph 4
B Brake/Clutch Master Cyl. Spridgets 8
T TR2/3/3A TR3A clutch&brake master cylinders Triumph 11
mountainman Brake and Clutch Master Cylinders Triumph 12
mountainman TR 3 Brake & Clutch Master Cylinders Triumph 2
Y Brake & Clutch Master Cylinders Triumph 1
T T-Series Clutch and Brake Master Cylinder Removal MG 22
I Brake and Clutch Master Cylinder Storage. Triumph 2
im_a_hypnotist 66 sprite mk III dual master brake/clutch cylinder Austin Healey 2
Steve P. master brake/clutch re-sleeve...suggestions Spridgets 3
Lin Brake/Clutch Fluid Austin Healey 11
K TR2/3/3A An Unusual Brake and Clutch MC Set Up? Triumph 2
C TR2/3/3A TR3A clutch/brake cylinder rebuild Triumph 4
fpstude TR4/4A Brake / Clutch Fluid for TR-4A Triumph 8
B Flushing brake/clutch Austin Healey 16
D TR2/3/3A clutch/brake pedal question Triumph 4
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
SD Bugeye Clutch and brake clevis and pins Spridgets 3
G Brake/clutch resevoid replaced do I have to bleed the system Austin Healey 9
vette Brake/Clutch Reservoir Austin Healey 14
M TR2/3/3A Fitting on Moss Brake/Clutch Masters Triumph 16
M TR2/3/3A Brake/Clutch Reservoir Seal Triumph 9
R Bug-eye clutch slave cylinder and brake cylinder kit interchange Spridgets 1
K TR2/3/3A Brake and clutch MC housing.... Triumph 2
petnatcar GAS, BRAKE and CLUTCH PEDALS for a BT7 Austin Healey 2
D Brake/clutch lines Spridgets 14
A TR2/3/3A TR3 Brake / Clutch Resevior & Lines needed Triumph 2
Rob Glasgow Brake/Clutch Reservoir Lines Austin Healey 9
S Clutch Fluid / Brake Fluid consumption Spridgets 3
B TR2/3/3A Gaskets for Brake/Clutch Fluid Reservoir? Triumph 15
D brake /clutch pedals Austin Healey 2
I TR2/3/3A Clutch and brake pedal assembly problem Triumph 4
jlaird Brake and Clutch bleeding Spridgets 7
PatGalvin TR2/3/3A Brake and Clutch pedal to MC adjustments? Triumph 4
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
K TR2/3/3A Brake and Clutch MC pushrod/pedal bolt stops? Triumph 2
nevets Replacing the brake/clutch fluid reservoir Austin Healey 21
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
C Sealing Healey clutch fitting on brake reservoiur Austin Healey 13
Jim_Newman brake/clutch fluid reservoir Austin Healey 4
Rut Brake and clutch pushrod Spridgets 1
