mountainman
I am trying to bleed my clutch and brake systems on my TR3. I have a full reservoir of fluid.
I started with the clutch and opened the bleed nipple. My assistant pumped the pedal several
times, but no fluid came out. Next I checked to make sure I had the 1/2" to 5/8" free play
on the push rod which I did. Then I took the pipe off of the master cylinder that feeds the
slave cylinder, pumped the pedal still no fluid. The PO said that both master cylinders wererebuilt and I have all new hydraulic lines on the car. What can be my problem?
Thanks
Greg
Thanks
Greg
