Pulling just the rocker arm?
Ralph_Y
Member
Can the rocer arm on an MGB be removed without destroying the head gasket seal? The car runs fine, I just think I have a worn rocker face or 4.
Nunyas
absolutely! You can remove the entire rocker assembly without removing the head. I've removed and rebuilt my rocker assembly about year and a half ago without removing the entire head, and without any ill side efffects.
jlaird
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif
Nunyas
The valve cover gasket on the other hand is a different story. Unless, of course, you have one of them new fangled "silicon" gaskets that are reusable. /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
tony barnhill
Great Pumpkin - R.I.P
Drain the radiator so the water is below the head level...back off all the head bolts in the proper sequence about half their torque...then remove the rocker assembly...when you put it back on, torque the head properly.
Ralph_Y
Ralph_Y
Member
Thank you folks!
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
J Engine Pulling Austin Healey 6
Basil Wife's BMW Z4 - pulling my hair out! Other Cars 29
AngliaGT MGB-GT '67 GT - Pulling Engine - Disconnect Driveshaft? MG 6
O Hesitation on pulling away from stop Jaguar 25
KVH TR4/4A Pulling Engine: Questions Triumph 6
steveg Newbie questions on pulling an engine Austin Healey 19
K TR2/3/3A Another question about pulling the wiring thru the stator tube... Triumph 15
T TR4/4A Remind me on pulling an engine and transmission together or seperate Triumph 11
T TR4/4A How to determine if the crank is good before pulling the engine out Triumph 8
trotti Pulling off the rear wheel cylinder Austin Healey 11
KVH TR4/4A Real Main Seal and Pulling the Engine Triumph 19
TomChar TR6 Pulling the starter Triumph 2
C Pulling to left Spridgets 8
N Midget pulling??? Spridgets 14
S Pulling the engine, clutch troubles? Spridgets 14
Rob Glasgow Pulling Engine Austin Healey 18
A pulling to the left Triumph 8
T Wedge Pulling TR8 trans in the driveway? Triumph 12
Boink The use of HTML coding [and pulling in graphics] FORUM Navigation Questions 2
B TR2/3/3A Pulling engine & trans on TR3B - hoist attach? Triumph 6
bugedd Pulling a datsun trans Spridgets 22
Darrell_Walker Pulling the plug.... Triumph 8
6 pulling engine Triumph 10
M Pulling the Engine Spridgets 12
Tugboat TR2/3/3A TR3A Intermittent Pulling When Braking Triumph 5
hondo402000 TR6 TR6 Engine pulling process Triumph 20
hondo402000 TR6 Pulling TR6 Engine Triumph 31
T TR4/4A Tips on pulling the TR4a differential apart Triumph 2
Nelson Pulling the engine Spridgets 3
J Pulling the engine Triumph 18
B TR2/3/3A Pulling TR3 body off question Thanks Triumph 15
T Engine pulling question - where connect Triumph 10
S MGB MGB pulling to rt. MG 6
J MGC MGC pulling Transmission MG 3
MadRiver MGC Pulling an MGC's head MG 8
T TR2/3/3A TR3A brakes pulling Triumph 7
T Tips on pulling a Bugeye 1098 & smooth case trans Spridgets 7
B Pulling Engine Austin Healey 4
tweety pulling catalytic conv... better performance? Spridgets 3
D Spitfire Spitfire rear wheel pulling Triumph 6
B pulling engine but need help....pictures!! Spridgets 11
C Pulling the motor and trans? Triumph 3
ronzet Pulling the tranny... MG 8
motofiaccone Engine pulling this week Spridgets 22
healeyboz pulling the harmonic balancer Spridgets 6
B MGA MGA Pulling halfshafts. MG 7
BoneIdle MGB-GT Draining and Pulling Tank on '74 GT - Advice? MG 7
10musketeer pulling dents out of an exhaust pipe? Spridgets 5
Jayrz Pulling hard to 5500 and MG 5
