rocker arm geometry
vrod
does any one know how to check the rocker arm geometry on a tr250 inline six. I have had the head skimmed from what I measured .110 thousands and the car is not running now because of a valve dropping down into number 3 cylinder caused from a broken valve spring. I think the engine needs shorter push rods to lesson the stress on the valve springs
piman
Hello Vrod,
firstly there are different length pushrod made by Triumph, with the 2.5 injection engine having shorter pushrods due to the thinner head. The geometry is fixed by the height of the rocker pedestals and for standard valves in a good head (i.e. not having the seats excessively recessed or cut back which would give a higher valve tip to head distance) should be correct if you are able to get the standard valve clearance. The thinner head, given the correct clearance, just means that the adjusting screw is higher in the rocker. With a standard cam the geometry should be unaffected. If you have a much higher lift cam than standard then you ideally need to machine the pedestals down, which then would almost certainly need shorter pushrods. Also you would need to be sure that the springs do not become coil bound. This is a common cause of breakage. If, as I outlined earlier, the clearances are correct then it is very unlikely that the spring breakage is due to the pushrod length.
Mechanically, the ideal geometry is with the rocker horizontal at 50% lift.
Alec
Dave Russell
Yoda - R.I.P
I don't think that push rod lengths have any direct bearing on the situation.
With the lash adjusters on the PUSHROD end of the arms, the adjuster settings have no bearing on the rocker arm geometry. If the adjuster lengths are still within the needed adjustment range no change is needed. Obviously, if the adjusters are backed all of the way out & you still do not have enough lash clearance, shorter pushrods are needed. If the adjusters were on the VALVE STEM end of the rockers, you would definitely need shorter pushrods to maintain correct geometry.
The rocker arm to valve stem geometry is determined by valve stem length & or valve seating depth & rocker pedestal height. The geometry should be such that the rocker tip contacts the valve stem at a little past center of of the stem when the valve is at 1/2 lift & the rocker is at 90 degrees to the stem. The object is to minimize the lateral (side to side) scrubbing of the rocker contact on the valve stem. Minor variations of this are usually the case & will likely be OK.
Ideally, the rocker tip radius is such that it matches the rocker arm arc of motion so that there is a rolling motion, rather than sliding, of the rocker tip across the valve stem. This usually is not the case & is why roller rocker arm tips are sometimes used. Especially with high lift cams which make the total rocker to stem contact lateral motion greater.
An easy check is to insert a thin piece of paper between the rocker tip & valve stem. With ideal geometry, the paper will not be cut by the valve stem as the rocker is cycled.
None of this should affect the valve springs unless the springs are coil binding when the valves are fully open. This can be checked by accurately measuring the length of a fully compressed spring (in a vice) & comparing it to the spring length when the installed spring is at the valve fully open position. The springs should be at longer than the fully compressed length by at least .100" with the valve fully open.
Careful measuring between an installed valve retainer (but minus the spring) & the spring seat will give the available spring length. This measurment minus the valve lift, must be .100" longer than the compressed spring length.
Corrections to the geometry can be made by changing valve stem lengths, valve seating depths, & rocker arm pedestal height. Some engines have shims under the rocker pedestals so that height may be adjusted.
Most production engines do not meet the ideal conditions & still work OK. Likely, you will not want to get involved with all of this. Spring coil bind is the most important consideration in the equation.
glemon Reground Cam Rocker Arm Geometry Austin Healey 11
WHT Rocker Arm Shaft Replacement Austin Healey 21
D TR6 Rocker arm assembly , pushrod clearance Triumph 8
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
D rocker arm assembly Austin Healey 14
matmire rocker arm stress cracks? advice please. Spridgets 2
T TR2/3/3A TR Rocker Arm Spacers Triumph 7
J TR2/3/3A Installing new rocker arm shaft. Triumph 6
KVH TR4/4A I Pulled the Rocker Arm Off Triumph 7
M TR2/3/3A TR3 Steering box rocker shaft and drop arm Triumph 5
M Rocker Arm without Oil Bleed Hole Austin Healey 4
64rocksprite rocker arm fitment - how close to 'center'? Spridgets 8
R dual springs for 1500 engine rocker arm upgrade? Spridgets 3
T Defective rocker arm shaft photo Triumph 12
T Rocker arm/shaft question Triumph 13
T Rocker arm assembly removal Triumph 24
Dadandson Roller Rocker arm Pics Spridgets 34
KVH Use of "Jam Nut" on Rocker Arm Tappets Triumph 8
T Rocker arm stud replacement Triumph 40
Hap Waldrop Rebuilding a rocker arm assembly Spridgets 16
ronzet Rocker Arm interchangability MG 3
Moseso Rocker Arm Clearances Triumph 4
A Rocker Arm failure MG 8
Tinkerman TR2/3/3A Locking screw on rocker arm shaft, TR-3 Triumph 4
M Rocker arm shaft question Austin Healey 11
Ralph_Y Pulling just the rocker arm? MG 5
K rocker arm needed, please help Triumph 6
healeyboz Rocker arm assembly Racing 6
healeyboz rocker arm assembly Spridgets 18
PAUL161 Rocker Arm / Valve Clearance -Hot or Cold MG 0
C Rocker arm play on shaft Austin Healey 12
PAUL161 Rocker arm lubrication question MG 5
Nunyas Rocker Arm question MG 51
M Rocker Arm Shaft Triumph 4
S Rocker Arm assembly Austin Healey 3
S GT6 GT6/TR6 rocker arm identification and questions. Triumph 0
V Rocker Arm and Push Rods Triumph 8
Patton Rocker Arm Specialists Austin Healey 3
Patton Rocker Arm Clearances too Large Symptoms Austin Healey 5
Patton Rocker arm fountain!!! Austin Healey 1
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
G Installing New Rocker Shaft Assembly Austin Healey 3
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
Hamish Racing General TR Rocker cover identification please. Triumph 2
H Rocker Cover Data Plate Austin Healey 15
Twit TR4/4A 1.5 in outside diameter rocker cover pipe Triumph 3
kodanja TR2/3/3A Rocker studs for aftermarket Rocker covers Triumph 4
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
