Rocker Arm Clearances
Moseso
I have searched the Complete Official TR3 Workshop Manual, high and low, and cannot find this information. Anyone got a clue?
'59 TR3 Motor:
I am replacing the old scored-up rocker shaft and the rocker arm bushings. The new rocker shaft measures 0.6234". If I ream the new bushings to 0.6250 that will leave 0.0016" clearance. Is that the proper value? More? Less?
Don Elliott
If I remember correctly, the rocker shaft does not rotate in the pedestals. Therefore they can be almost a light press fit. You will only need to rotate them once so that all the pedestal bases are flat on the bottom where they sit on the head when you tighten the assembly down. I would say "less clearance than you suggested".
Moseso
Moseso
Don --
Wrong parts, but thanks for trying. I know the pedestals should be a tight fit on the shaft.
It's the rocker arms -- which most assuredly DO move on the shaft -- that I want the clearances for. I replaced the bushings in the eight rocker arms -- 2 per arm -- and now need to ream them to some proper clearance on the arm. Right now they are .010" - .012" smaller than the diameter of the shaft -- and I know THAT'S not right...
Moseso
Moseso
Really????
No one has an answer for this????
piman
Hello Moseso,
I can't quote for a TR4, but for the Triumph six cylinder these are the official dimensions:-
Shaft diameter 0.5607" to 0.5612"
Rocker bore 0.562" to 0.563" 2000cc engine
0.563" to 0.564" 2500cc engine.
From that the maximum clearance is 0.0023" for a 2000 and 0.0033" for a 2500. Why there is a difference I don't know, seems rather odd?
Alec
Patton Rocker Arm Clearances too Large Symptoms Austin Healey 5
WHT Rocker Arm Shaft Replacement Austin Healey 21
D TR6 Rocker arm assembly , pushrod clearance Triumph 8
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
D rocker arm assembly Austin Healey 14
matmire rocker arm stress cracks? advice please. Spridgets 2
T TR2/3/3A TR Rocker Arm Spacers Triumph 7
J TR2/3/3A Installing new rocker arm shaft. Triumph 6
KVH TR4/4A I Pulled the Rocker Arm Off Triumph 7
M TR2/3/3A TR3 Steering box rocker shaft and drop arm Triumph 5
M Rocker Arm without Oil Bleed Hole Austin Healey 4
64rocksprite rocker arm fitment - how close to 'center'? Spridgets 8
R dual springs for 1500 engine rocker arm upgrade? Spridgets 3
T Defective rocker arm shaft photo Triumph 12
T Rocker arm/shaft question Triumph 13
T Rocker arm assembly removal Triumph 24
Dadandson Roller Rocker arm Pics Spridgets 34
KVH Use of "Jam Nut" on Rocker Arm Tappets Triumph 8
T Rocker arm stud replacement Triumph 40
Hap Waldrop Rebuilding a rocker arm assembly Spridgets 16
ronzet Rocker Arm interchangability MG 3
A Rocker Arm failure MG 8
Tinkerman TR2/3/3A Locking screw on rocker arm shaft, TR-3 Triumph 4
M Rocker arm shaft question Austin Healey 11
glemon Reground Cam Rocker Arm Geometry Austin Healey 11
Ralph_Y Pulling just the rocker arm? MG 5
K rocker arm needed, please help Triumph 6
healeyboz Rocker arm assembly Racing 6
healeyboz rocker arm assembly Spridgets 18
PAUL161 Rocker Arm / Valve Clearance -Hot or Cold MG 0
C Rocker arm play on shaft Austin Healey 12
PAUL161 Rocker arm lubrication question MG 5
Nunyas Rocker Arm question MG 51
M Rocker Arm Shaft Triumph 4
S Rocker Arm assembly Austin Healey 3
S GT6 GT6/TR6 rocker arm identification and questions. Triumph 0
V Rocker Arm and Push Rods Triumph 8
V rocker arm geometry Triumph 2
Patton Rocker Arm Specialists Austin Healey 3
Patton Rocker arm fountain!!! Austin Healey 1
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
G Installing New Rocker Shaft Assembly Austin Healey 3
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
Hamish Racing General TR Rocker cover identification please. Triumph 2
H Rocker Cover Data Plate Austin Healey 15
Twit TR4/4A 1.5 in outside diameter rocker cover pipe Triumph 3
kodanja TR2/3/3A Rocker studs for aftermarket Rocker covers Triumph 4
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
