Rocker Arm assembly
shorn
Can someone tell me exactly what to look for in a worn rocker arm assembly. I know there may be too much oil coming out of the rocker arms, I know it should only be a drop a second or so and shouldn't spurt up. But is it the clearance between the rocker arms and the shaft that actually wears? Can one tell if there is too much wear by moving the rocker arms sideways to check for play? Since I had water in my oil under the rocker arm cover before a new head gasket, I am wondering if that (the water) might have caused some problems.
Keoke
Hi Shorn, if you do not have excessive oil spurting out of the rockers I would guess your shaft is OK and the water did not adversly effect the assembly..---Fwiw---Keoke
rustynuts
I just had my assembly apart recently. Laid all the parts on a rag in order. Then cleaned each one in the parts washer and reassembled it onto the shaft. The shaft was shiny on the underside from the upward forces and each rocker and support was firm when slide along the shaft into position. I did have to insert a screwdriver into one of the holes in the R-shaft to hold some of the rockers since the large springs between them where difficult to keep compressed . As in my case with the lack of a properly maintained oil filtering system, some of the small hole in the rockers had been plugged and consequently reduced the flow of oil onto the rockers. The rockers should be firm on the shaft when checked without any load put on them from the pushrod. I had to use 2000 grit emery cloth to remove the surface crud that had accumulated on the shaft in areas between the rockers in order to get the rockers and supports off the shaft. Also remember to run the emery over the holes in the end that the cotter pins are in to remove any bur that might score the rockers . Hope this answers your question!!!!!
S
shorn
I found what I think is a fair amount of wear on the shaft under the rockers. The shaft is no longer shiny under the rockers. At idle a couple of the holes seem to be putting out more oil than the rest, although it is not spurting. In any event I removed the assembly and sent it off to Rocker Arm Specialist. It will be renewed and back in a week. Cost $144.
D TR6 Rocker arm assembly , pushrod clearance Triumph 8
D rocker arm assembly Austin Healey 14
T Rocker arm assembly removal Triumph 24
Hap Waldrop Rebuilding a rocker arm assembly Spridgets 16
healeyboz Rocker arm assembly Racing 6
healeyboz rocker arm assembly Spridgets 18
WHT Rocker Arm Shaft Replacement Austin Healey 21
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
matmire rocker arm stress cracks? advice please. Spridgets 2
T TR2/3/3A TR Rocker Arm Spacers Triumph 7
J TR2/3/3A Installing new rocker arm shaft. Triumph 6
KVH TR4/4A I Pulled the Rocker Arm Off Triumph 7
M TR2/3/3A TR3 Steering box rocker shaft and drop arm Triumph 5
M Rocker Arm without Oil Bleed Hole Austin Healey 4
64rocksprite rocker arm fitment - how close to 'center'? Spridgets 8
R dual springs for 1500 engine rocker arm upgrade? Spridgets 3
T Defective rocker arm shaft photo Triumph 12
T Rocker arm/shaft question Triumph 13
Dadandson Roller Rocker arm Pics Spridgets 34
KVH Use of "Jam Nut" on Rocker Arm Tappets Triumph 8
T Rocker arm stud replacement Triumph 40
ronzet Rocker Arm interchangability MG 3
Moseso Rocker Arm Clearances Triumph 4
A Rocker Arm failure MG 8
Tinkerman TR2/3/3A Locking screw on rocker arm shaft, TR-3 Triumph 4
M Rocker arm shaft question Austin Healey 11
glemon Reground Cam Rocker Arm Geometry Austin Healey 11
Ralph_Y Pulling just the rocker arm? MG 5
K rocker arm needed, please help Triumph 6
PAUL161 Rocker Arm / Valve Clearance -Hot or Cold MG 0
C Rocker arm play on shaft Austin Healey 12
PAUL161 Rocker arm lubrication question MG 5
Nunyas Rocker Arm question MG 51
M Rocker Arm Shaft Triumph 4
S GT6 GT6/TR6 rocker arm identification and questions. Triumph 0
V Rocker Arm and Push Rods Triumph 8
V rocker arm geometry Triumph 2
Patton Rocker Arm Specialists Austin Healey 3
Patton Rocker Arm Clearances too Large Symptoms Austin Healey 5
Patton Rocker arm fountain!!! Austin Healey 1
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
G Installing New Rocker Shaft Assembly Austin Healey 3
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
Hamish Racing General TR Rocker cover identification please. Triumph 2
H Rocker Cover Data Plate Austin Healey 15
Twit TR4/4A 1.5 in outside diameter rocker cover pipe Triumph 3
kodanja TR2/3/3A Rocker studs for aftermarket Rocker covers Triumph 4
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
