TR6 Need clutch hydralic line ideas [TR6]
ALLAN
I have converted to the Toyota transmission and am trying to figure out if I should go with the stock hydraulic line with an adapter to the Toyota slave, or have a new line made up. I know some of you have gone with something different than stock and I need some Ideas on what kind of line and fittings to use if I dont go stock ??
Brosky
I used the stainless steel braided line from TRF. After 33 years, I was pushing my luck with the original plastic line. Surprisingly, it didn't look too bad when we took it off.
I did replace all of the hydraulics and converted to silicone fluid at the same time.
A
ALLAN
I will have to check that braided line out---I have redone all my hydraulics and going with silcone too. I know there are some downsides to the silicone but not having to worry about my paint is to much of a plus not to.
martx-5
If you have the HVDA Toyota trans conversion, page 22 of Herman's instruction manual specifically says NOT to use silicone (DOT 5) fluid for the hydraulic throw out bearing. He says to use DOT 4.
A
ALLAN
Thanks,I have the Conversion Components conversion, it has a Toyota slave cylinder and a fork to throw out bearing.-------Does anybody have TRF part # for the braided line? Moss has one for $50
Brosky
Allan:
This is the TRF hose, with their slave.
Don't bother adding the oil drips on the header like a certain guy with sloppy, oily hands did after changing the oil and filter today.
One thing about TR6 oil leaks. They do keep the frames from rusting.
Brosky
Allan,
My mistake. I apologize. TRF was out of slaves and DID NOT sell SS braided line, so I bought almost the entire setup from Moss. The part number for the SS hose is 584-785. Make sure that you get this fitting also, part number 589-140. It goes between the steel line from master to flex line.
I did buy a new custom bent steel line that runs from the master to the fitting before flexible braided line from TRF. They are the only ones that custom bend these today.
Don't bother with the adjustable clutch rod from TRF. So far as I can see, a $40.00 waste of money.
Sorry about the error!
DNK
Does BPNW sell those?
Hey Paul, who makes your header?
G
Brosky said:
The stainless, braided clutch line is a good idea but remember that braided lines will cut anything they rub against. I wound mine with some of the translucent poly split wire wrap material. So, in essence, I am using the braided line to protect the rubber hose inside it and poly line to protect other components from the braided line. Kinda gets crazy.
Paul, a thought, and it may be too late, but traditional U-bolt muffler clamps distort any exhaust pipe to the point that taking it back down becomes impossible. I resorted to using Stainless Specialties' stainless band clamps, lines with multiple wraps of heavy duty aluminum foil (and a strip of asbestos ... not supposed to have that) and these babies seal perfectly, and allow the pipes to come apart with relative ease. If and when you have to do that....I have had to do it 3 times. The clamps are reusable, once.
Brosky
Bill,
I agree with what you say, but it is probably too late. Well, maybe not, if I were to put a pipe expander inside each side and crank it up to round out the pipes again.
I'm not too worried about it at this point.
DNK, it's a PaceSetter header, coated inside and out with Jet-Hot coating. It runs very cool, actually cooler than a stock manifold by anywhere from 5-10 degrees.
Soup
Paul - Did you notice any loss in power at low rev.'s and what did it do to the sound of the car?
I'm pretty sure your not using a Monza exhaust. I picked one up last summer as part of all the work necessary to get the car going and I'm really not happy with it. Too loud around Town but fine on the highway. I'm wondering if a header might calm the Monza down a bit.
swift6
TR6BILLPaul said:
I've found that if you use a two stage tightening method for the traditional U-bolt muffler clamps then they don't distort as badly (affecting removal) and actually seal much better. First figure out where you want the final position of the clamp to be but do not tighten it. Turn the clamp 90 degrees and tighten down. Now, loosen the clamp, turn it to your pre-determined final position and tighten it down. When it time to remove the pipe, I reverse the process and the pipes come apart pretty easily.
Bill, does bring up a good point though about there now being much better exhaust clamps on the market.
Brosky
Soup,
I lost no power on the bottom end whatsoever. I actually gained power across the entire range. I have stock exhaust, which sounds great with the headers.
I also have a modified distributor and slightly richened carbs.
I'll let you know how everyone plays together after the tri-carb setup in two weeks.
Brosky
Shawn,
I agree with both you and Bill and your thoughts are great methods of keeping the connections easy to service.
71tr
There is usually a braided SS clutch line for sale on ebay, check out auction # 120102816815.
K TR4/4A Need help with clutch issue... Triumph 2
1 MGB I don't know how or why, but I think I will need a new clutch :[ MG 4
J Clutch Woes - Need some technical assistance Spridgets 5
bugedd Rivergate clutch issues, need help Spridgets 9
Jims71TR Clutch Problem need Help Triumph 14
CZ_Dave T-Series Need Help, Clutch/Brake MC on 1959 Magnette MG 3
1 T-Series Parts I'll need for clutch job? MG 16
T Need a clutch alignment tool to install trans? Triumph 27
M Need Clutch Help Spridgets 12
danielnorton need clutch help Spridgets 65
T Need help with clutch Triumph 41
K TR4/4A Clutch Replacement on TR4A. need advice Triumph 11
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
