Exhaust System
Gary_D
Member
Would like imput on the size of exhaust pipes. I have a 1098 bored out to 40 over, APT street preformance cam, Pace header and a Monza exhaust. I'm ready to install a one peice pipe from the header to muffler and would like to have it mandrel bent so it goes up and over the rear axle so the muffler will not hang so low. The smallest that can be bent this way is 2" dia. Will the increase in size from 1 3/4" to 2" cause me any problems in lost torque? I can go with crush bent pipe, but am worried that I would end up with an ID less than 1 3/4" if I stay with current size(1 3/4") and don't want to restrict the exhaust flow. Anyone one have experence going either way with this?
Thanks, Gary and Little Red
Jim_Gruber
Gary, Hey Bugsy my '68 Sprite has a 1098 as well. You're not alone. A little more power would be appreciated but right now happy to have Bugsy running sweet once again.
regularman
Seen a lot of people keep it straight all the way back and use a harley slip on at the very end and then it doesn't hang any lower than one like you are talking about. Those slip ons are always on Ebay pretty cheap and brand new where folks have taken them off for louder aftermarket slip ons and want to get rid of the quiet ones.
G
Gary_D
Member
Thanks guys,for your responses. But.........I have a problem. After getting the car back after a year rebiuld, we had our first road trip on Sunday. Went to the Eastern Shore of Maryland to Punkin'in Chunk'in. Ever seen a punkin(thats what they call'em over there) fly over 4,000ft? Pretty impressive. Made it home Ok. Monday after work I was on the way to the muffler shop so they could take a look. About a mile from the house the car filled with smoke. Turned Little Red off, got her off the road, popped the hood, yea, no flames. Got the fire extinguisher from the trunk(every LBC should have one on board)and looked under the dash after the smoke cleared.
A wire that is conected to the ignition switch was FRYED. After that, one could say that I needed to check my shorts! No damage to the car other that replacing some wiring. Guess it will be awhile before I worry about exhaust issues.
jvandyke
If you want to try a harley pipe let me know, you can have it for shipping cost. I never got around to fitting it and probably won't.
BTW
1098s are great
tony barnhill
Great Pumpkin - R.I.P
BTW 1098s are great
Were it me, based on the angle I see in the photos, I'd rotate that rear pipe 180-degrees so the exhaust is pushed downwards not up into the sky.
theleisure
Bronze
tony barnhill said:
BTW 1098s are great
You're right Tony. Not only in the direction of the exhaust, but also due to the fact that it'll give you some extra clearance if you have to back up out of a steep driveway.
aeronca65t
Gary_D said:
.....About a mile from the house the car filled with smoke. Turned Little Red off, got her off the road, popped the hood, yea, no flames. Got the fire extinguisher from the trunk(every LBC should have one on board)and looked under the dash after the smoke cleared.
A wire that is conected to the ignition switch was FRYED. After that, one could say that I needed to check my shorts! No damage to the car other that replacing some wiring.....
Yeah, I know how *that* feels.
In fact I caught mine ~On Video~ (slide the time line to about 8:15)
jvandyke
If it sticks around I might try it. Just need to get some reducers. I'm really interested to hear what it sounds like. When I went to fit it, I managed to refit my Monza pipe which was too low and too far out and frequently hit, now it never does and looks much better, sounds good too. Only reason for the Harley test is potentially different sound, that fat pipe looks cool too. The slash cut is angled up because the mounting point is on that side, I'm sure you could finagle something to flip it.
ChrisS
1-1/2" EMT electrical conduit is 1.74" OD. Makes great exhaust pipe when you need it on a Sunday. That being said, if you need a mandrel bend make friends with an electrician. The standard radius on their 1-1/2" bender is something like 8" or 9".
regularman
You could probably do that with a Chicago bender but to do a proper mandrel bend, you have to have something inside. Conduit benders don't have and inside piece but make sweet bends. I band conduit but I could never bend 1 1/2 anywhere close to the needed radius for that. You might get 1" to work. I thought of running 4 separate 3/4" stainless out the back just to see what that sounds like.
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Stainless Steel Exhaust System Wanted Austin Healey 5
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
60TR3A TR2/3/3A Exhaust System Recommendations Sought Triumph 15
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
S Side exhaust system for BJ8 Austin Healey 16
D TR2/3/3A Exhaust system routing and middle clamp Triumph 8
H BJ8 Exhaust System and Brake Servo Austin Healey 16
Keith_M Exhaust System for a Bugeye Spridgets 14
tr3guy TR2/3/3A New TR3 Exhaust System Triumph 6
J BJ8 Ph I Exhaust System Austin Healey 3
sundown TR6 1973 TR6 mossmotors sport exhaust system Triumph 6
B Exhaust system recommendations. Austin Healey 9
Boggsy64 MGB Modify new exhaust system for ground clearance? MG 1
B Exhaust System Replacement Austin Healey 10
D Installing BJ7 version exhaust system on my BJ8 Austin Healey 3
Xte How to fix my new BJ8 SS exhaust system ? Austin Healey 5
S AH Exhaust System Austin Healey 5
M Question about Moss Exhaust System [pics] Triumph 27
R Exhaust system cunumgrums Austin Healey 2
G MGB MGB exhaust system MG 11
Rut Exhaust system Spridgets 11
Darrell_Walker TR4/4A TR4A exhaust system options Triumph 7
R Monza Exhaust System Austin Healey 0
R Stainless Steel Exhaust system Austin Healey 14
PatGalvin TR2/3/3A TR3 Exhaust System - how does it fit Triumph 3
ArtQ exhaust system Austin Healey 6
M MGC MGC Performance Exhaust System MG 11
mrdibbles Abarth Exhaust System for Austin Healey 3000 BT7 Austin Healey 11
T TR2/3/3A Question? TR3A exhaust system Triumph 9
BOBBYR Moss exhaust system???? Austin Healey 19
Monark192 MGB-GT 67 BGT - Needs new exhaust system - Suggestions? MG 8
BOBBYR 65 A.H. 3000 exhaust system ???? Austin Healey 13
Magyar New Exhaust System Spridgets 8
RickB MGB-GT Exhaust system options 70 MGB-GT? MG 7
H Exhaust system for BN 7 Austin Healey 3
RSMTR8 Wedge TR8 Exhaust System Triumph 8
J midget 1500 exhaust system Spridgets 3
M Exhaust System Install Problem Triumph 3
RSMTR8 Wedge TR8 Exhaust System Triumph 5
roofman TR6 TR6 Exhaust system ideas NOW WITH A PICTURE !!!!! Triumph 39
A TR6 Bell Stainless Exhaust System,tr6 ?? Triumph 7
Aeroken TR6 TR6 Exhaust System Mounts Triumph 2
Wana Need suggestions regarding exhaust system Austin Healey 23
nevets condensation in the exhaust system Austin Healey 7
MGTF1250Dave TR2/3/3A TR3 Exhaust System Resonator Triumph 3
Howard_The_Duck Bell Exhaust System.... Any Thoughts? MG 8
T TR6 72 tr6 exhaust system Triumph 18
R Abarth free flow exhaust system Austin Healey 7
P exhaust system Jaguar 19
