suspension bushings
sheldon
good morning, This weekend bead blasted suspension and painted and now ready for assembly any feedback on poly bushins vs rubber would be appreciated thanks
Patrick67BJ8
From the issues brought up on the Forum, I'd go back to original bushings. I am doing a ground up restoration and I'm putting back in the original stuff. Unless your racing you won't need the "stiff" bushings. PM me for a great source for them.
Patrick
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
R TR2/3/3A Front Suspension Polyurethane Bushings Triumph 2
J TR2/3/3A Suspension bushings Triumph 0
J TR2/3/3A Suspension bushings Triumph 3
P Installing suspension bushings Austin Healey 5
ahealey1004 how to remove front suspension inner bushings? Austin Healey 6
G Front Suspension Bushings Question MG 3
tomshobby Which front suspension bushings? Spridgets 15
kennypinkerton Suspension bushings - how many? MG 4
kennypinkerton Replacing Suspension bushings... MG 6
Atrus A few rear suspension Q's [springs & bushings] Spridgets 10
jlaird Oh me, The post on front suspension bushings Spridgets 7
vping Need Tips on Replacing Rear Suspension Bushings MG 7
T TR2/3/3A Poly bushings for TR3 front suspension Triumph 7
D Suspension Bushings Lotus 6
J Poly suspension bushings MG 7
J front suspension bushings. - how big of an effort? Triumph 19
jlaird Question, suspension bushings Spridgets 24
N Front End Suspension Bushings MG 7
jfslenes Front Suspension HiPo Bushings Sunbeam (Rootes) 1
M TR2/3/3A Rebuilding suspension Triumph 29
K TR6 Rule of thumb for frt suspension shims Triumph 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
Racer-X- Special Suspension tools 18G95 and 18G78 British Motor Corp 1
P Suspension upgrade for a A40 Devon. British Motor Corp 0
HealeyPassion Kilmartin Front Suspension Gussets Austin Healey 4
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
L TR6 MII Suspension Triumph 6
R TR6 Rear suspension droop restraint Triumph 0
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
crispy BJ8 Front Suspension Austin Healey 9
Healey Nut BT7 Rear Suspension Austin Healey 15
D MGB Rear Suspension Damper Link Arm MG 2
R TR6 Front suspension fulcrum pins Triumph 6
Michael Oritt Evaluating Suspension Components Austin Healey 4
Upland Mark IV front suspension Spridgets 3
JPSmit Suspension question Spridgets 1
S TR2/3/3A Front Suspension Triumph 6
J Front Suspension Rebuild Austin Healey 16
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
EWD TR6 74 TR6 - suspension bushing tightening Triumph 1
M TR6 suspension puzzle Triumph 3
Jayplum TR2/3/3A Front suspension / springs Triumph 5
TRclassic3 TR4/4A Help with deciphering front suspension problem Triumph 11
L 100/6 tuning and suspension ugrades advice Austin Healey 7
F TR4/4A Front Suspension Triumph 3
