Hello all. I am replacing all suspension bushings on my 62 tri carb and was able to remove front inner bushings on the wishbone arm with help from the forum. I ordered 8 new rubber bushings from moss part 021-187. I am not having luck installing the new ones. The old ones were so bad that its difficult to compare but it seems the new ones have pretty thick shoulder. The problem is that when I try to tighten with the large special washer and the castle nut, it seems impossible to tighten enough to get the special washer back into the chassis mounting bracket. Extremely tight. Is there a trick or perhaps did they send the wrong rubber bushing? It just seems that the assy is too fat overall to fit into the chassis bracket. Any help would be greatly appreciated.
