Rear Hub Removal - How Do I?
cechiodo
Replacing the brake shoes on my '65 MkIII. Trying to get the last two bolts off the LH rear hub extension didn't go well despite using copious quantities of Liquid Wrench and a breaker bar. They are now rounded badly and/or mangled. One of the biggest challenges is keeping the drum/hub from rotating. I'm thinking heat and vise grips 1st and then a grinder if all else fails. Any recommendations from experts on getting them off?
Thank you.
Chris (considers himself to be somewhat mechanically inclined) Chiodo
HealeyRick
I'm assuming you've set the parking brake and put the transmission in reverse to keep the wheels from turning? If so and its still turning, have a helper step hard on the foot brake. Go online at Sears.com and look for a "Damaged Nut Remover" set and make sure they have one in the size needed for the nut you're removing. They probably have it at your local Sears. I think Kmart and Ace hardware also carry Craftsman tools
Keoke
Switch penetrent to PB Blaster may work better.
steveg
Thank you.
You can rig up a lever such as a breaker bar, between the studs, to a jackstand, such that when you turn your wrench the lever is pressing down on the jackstand.
I bought one of the harbor freight lug wrenches and on the one that fits the healey, ground the edge flat so there's maximum contact with the flats.
https://www.harborfreight.com/20-inch-four-way-lug-wrench-94110.html
Amen to use of PBblaster or Kroil. Propane torch would help, too.
https://www.scuderiasilva.com/ has good prices on replacement locknuts.
C
cechiodo
Thanks HealeyRick,
Of course I completely disassembled the E-Brake side first. Clamping the drum to the backer plate did the trick to keep the thing from spinning. I was wondering if a nut remover existed for an 11/16 bolt & it looks like Sears has just the ticket. A five piece set for $10 - sort of like the inverse of a screw remover.
C
cechiodo
Thank you steveg,
Good suggestions and appreciate the lead on Scuderia Silva.
Chris
C
cechiodo
Thanks all for the suggestions on removing the hub nuts. They are all off and I need to buy a few to replace the mangled ones;) Combination of PB blaster*, 11/16 nut remover and rebar balanced on a jack stand to prevent rotation. Now off to get the drums turned. Any suggestions on balancing them? It occurred to me this might be something to look into whilst they are off the car.
Thank you.
Chris
*used it to service the bottom bracket on my bike too - good stuff!
K TR2/3/3A Rear axle hub removal? Triumph 8
T TR2/3/3A Rear Hub Stud Removal Triumph 4
PHerder Rear Hub Removal??? Spridgets 10
T REAR HUB REMOVAL Spridgets 4
doughairfield TR4/4A TR4 Rear Hub removal Triumph 14
drooartz Rear hub oil seal removal Spridgets 4
E Bugeye Rear Hub Removal Spridgets 5
Atrus Rear Hub bearing removal Spridgets 22
frankenstang57 Spitfire Spitfire rear hub removal? Triumph 11
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
W Rear Axle Hub Seal Austin Healey 8
W Rear Hub Reassembly Austin Healey 7
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
Rob Glasgow Rear Hub Nuts Austin Healey 11
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
Lin Rear Axle Hub Nuts Austin Healey 3
J TR2/3/3A Hole in Rear Hub Triumph 7
K Rear Hub Re-assembly Austin Healey 4
KVH General TR Rear Hub Backing Plate Triumph 1
Jim_Gruber A Victory to report over those bastard Rear Drum Circlips for Bugsy IV/Hub rubbing Spridgets 3
drooartz Rear wheel hub oil seal Spridgets 6
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
G Loose lugs on rear hub Austin Healey 7
KVH TR4/4A Here'a Another Rear Axle Hub Question/Problem Triumph 7
AngliaGT TR6 Need a Rear Hub Triumph 1
D Rear hub confusion Austin Healey 5
A TR5/TR250 Who still rebuilds Rear Hub Assemblies? Triumph 15
B Spitfire advice on rear axle/hub Triumph 4
TulsaFred Rear Hub bearing and oil seal tips Spridgets 0
TulsaFred Rear hub oil seals and bearings Spridgets 7
B Rear Hub Extension Studs Austin Healey 22
J Rear Hub/Bearing Question Spridgets 4
Dougal BN1 rear hub markings Austin Healey 3
M TR2/3/3A TR3 rear axle hub gasket ???? Triumph 4
Barryp Rear hub seal speedy sleeves? Austin Healey 2
R Spitfire Spitfire - Rear Hub disassembly help! Triumph 2
pkmh Removing Rear Hub on BJ8 Austin Healey 48
JPSmit Rear Hub Question Spridgets 2
Pete_Chadwell TR6 TR6 Rear Hub question, plus gearbox vibe Triumph 8
Lin Rear Hub Extension Nuts: Attention Rich Berman Austin Healey 23
MadRiver Rear Hub Puller? Austin Healey 4
glemon Bent Rear Hub/Axle Triumph 2
D BT7 Brake Overhaul and rear hub seal replacement Austin Healey 4
D Left rear hub nut Austin Healey 9
D Rear Hub install Austin Healey 2
6 TR4/4A Advice on stripped Rear Hub wheel stud for TR4 Triumph 24
dklawson Spitfire Spitfire - Rear Hub Bearing & Axle Assembly Steps? Triumph 17
boxfullofyertoys Rear hub nut size Spridgets 10
