Rear Hub install
dvu101
I have a BT7 and just finished putting in new seals in my rear hubs and had the bearings pressed back in.
What is the beat way to get the hubs back on the car?
I used the axle reversed and a gear puller to get it off.
Thanks in advance.
Scott
What is the <span style="font-weight: bold">beat</span> way to get the hubs back on the car?
Thanks in advance.
Scott
Freudian slip?
You can use a mallet and drift, but only use impact on the inner race. Ideally, you'd have a piece of tube laying around with the appropriate id/od.
I don't remember mine requiring that much force to remove/replace...
dvu101
Ok thanks. I had to use a lot of force to get it off. But now that it is all cleaned up and painted, maybe it will just slip on. Ha.
I think it was just tired that night when I wrote beat.
Thanks Scott
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
W Rear Axle Hub Seal Austin Healey 8
W Rear Hub Reassembly Austin Healey 7
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
Rob Glasgow Rear Hub Nuts Austin Healey 11
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
Lin Rear Axle Hub Nuts Austin Healey 3
J TR2/3/3A Hole in Rear Hub Triumph 7
K Rear Hub Re-assembly Austin Healey 4
KVH General TR Rear Hub Backing Plate Triumph 1
Jim_Gruber A Victory to report over those bastard Rear Drum Circlips for Bugsy IV/Hub rubbing Spridgets 3
drooartz Rear wheel hub oil seal Spridgets 6
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
K TR2/3/3A Rear axle hub removal? Triumph 8
G Loose lugs on rear hub Austin Healey 7
KVH TR4/4A Here'a Another Rear Axle Hub Question/Problem Triumph 7
T TR2/3/3A Rear Hub Stud Removal Triumph 4
AngliaGT TR6 Need a Rear Hub Triumph 1
C Rear Hub Removal - How Do I? Austin Healey 8
D Rear hub confusion Austin Healey 5
A TR5/TR250 Who still rebuilds Rear Hub Assemblies? Triumph 15
B Spitfire advice on rear axle/hub Triumph 4
TulsaFred Rear Hub bearing and oil seal tips Spridgets 0
TulsaFred Rear hub oil seals and bearings Spridgets 7
B Rear Hub Extension Studs Austin Healey 22
J Rear Hub/Bearing Question Spridgets 4
PHerder Rear Hub Removal??? Spridgets 10
Dougal BN1 rear hub markings Austin Healey 3
M TR2/3/3A TR3 rear axle hub gasket ???? Triumph 4
Barryp Rear hub seal speedy sleeves? Austin Healey 2
R Spitfire Spitfire - Rear Hub disassembly help! Triumph 2
pkmh Removing Rear Hub on BJ8 Austin Healey 48
T REAR HUB REMOVAL Spridgets 4
JPSmit Rear Hub Question Spridgets 2
Pete_Chadwell TR6 TR6 Rear Hub question, plus gearbox vibe Triumph 8
doughairfield TR4/4A TR4 Rear Hub removal Triumph 14
Lin Rear Hub Extension Nuts: Attention Rich Berman Austin Healey 23
MadRiver Rear Hub Puller? Austin Healey 4
glemon Bent Rear Hub/Axle Triumph 2
D BT7 Brake Overhaul and rear hub seal replacement Austin Healey 4
D Left rear hub nut Austin Healey 9
6 TR4/4A Advice on stripped Rear Hub wheel stud for TR4 Triumph 24
dklawson Spitfire Spitfire - Rear Hub Bearing & Axle Assembly Steps? Triumph 17
boxfullofyertoys Rear hub nut size Spridgets 10
B Right hand side rear hub nut Austin Healey 3
dklawson Spitfire Spitfire MkIV - Rear Hub Questions Triumph 4
M MGB MGB Banjo Rear Hub re and re wire wheels MG 0
ncbugeye Oil from rear hub Spridgets 3
