Torque on Midget rear wheel hub nut
BJ8Healeys
Does anyone know what torque should be applied to the Midget rear axle hub nut (disc wheels)? If so, can you cite the source where you found that value?
Yes, I know the left side nut is left-hand thread.
Thanks!
Joe Schlosser
As far as I know it is 140 ft #. However I cannot find my docs for the value. I cannot find in my shop manual but have been using this torque for forever.
You need to grind the face of the socket flat so that you are getting full engagement on the thin nut.
This prevents the socket sliding off the nut.
Jim_Gruber
140 lbs is the value I have been using as well. It's a big nut.
BJ8Healeys
BJ8Healeys
Thanks to all who replied. I've found that the nut on the left side won't go anywhere near 140 lb-ft. It is apparently stripped and won't go above about 20 lb-ft before it slips.
Joe Schlosser
Sounds like the PO did not know it was a LH thread. Easy to get new ones. How are the threads on the axle stub??
BJ8Healeys
BJ8Healeys
Joe, the "PO" who stripped the thread was me. I bought this car in 1987. It is so long ago now that I don't remember why I was removing the nut, but I found it very stubborn until I really cranked on it (in the wrong direction not knowing it was left-hand thread) and stripped it. Then, I knew it was LHT. I screwed it back on with some Loc-Tite as much as I dared without reaching the strip point. The Loc-Tite really doesn't do anything since the washer behind it locks the nut. When I removed it a couple days ago to change the rear bearing, it broke loose at 25 lb-ft. I suspected that was not the required torque, but I've put 60,000 miles on the car after stripping the nut with no obvious problems --- unless that is why the rear bearing needs changing now. As far as I know, the bearing is original to the car, which would make it 147,000 miles on it. I was beginning to hear some bearing noise from back there. I am changing both bearings.
As far as I can tell, the threads on the axle housing are O.K. I would expect that if anything was going to strip it would be the nut threads first, not the axle housing. However, I wish I had a die to chase the threads before installing a new nut.
nomad
There is a thread file available for odd sized threaded items. Try Amazon.
Kurt
BJ8Healeys
BJ8Healeys
Closer inspection determined that the threads on the axle housing are not as good as I first thought. I have ordered a new nut and the thread file (the pitch is 16 tpi). Thanks for the suggestion, Kurt. I have a spare rear axle housing that I salvaged from a '72 Midget years ago, but the threads on its left side are also boogered (or "mommicked" as folks in eastern North Carolina say). At least, I have a housing that I can use for practice with the file before I tackle the one on the car.
I surmise that the left-hand threads and high torque on the axle nut is to ensure that the nut sufficiently clamps the inner race of the bearing so that it doesn't spin on the axle and the nut doesn't loosen with the friction due to tire rotation. But since the nut is clamped by the lock washer anyway, it seems making it a left hand thread only increases the probability that some idiot will strip it trying to get it off.
startech47 1979 Midget rear hub bearing nut torque spec. Spridgets 3
bcbug 76 midget torque specs Spridgets 2
Lin Oil sump torque value? Spridgets 3
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
D Torque Sticks Restoration & Tools 6
J TR2/3/3A Head Torque - Wet or Dry Triumph 6
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
R Our J-H plan - torque specs needed! Other British Cars 2
S Locknut - rear wire wheel - torque spec? Austin Healey 15
S TR2/3/3A Torque specification on large pitman arm nut Triumph 1
Michael Oritt Torque values needed for 100 Austin Healey 5
R General Tech Crank bearing cap broke...Torque?? Triumph 37
Michael Oritt Torque Setting needed Austin Healey 10
M Replacing front shocks, torque setting? Spridgets 2
G Torque for Front Pinion Nut Austin Healey 3
Drone Dog torque values Austin Healey 2
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
Jim_Stevens TR2/3/3A Axle to leaf spring torque Triumph 2
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
G TR4/4A ARP Bolt Torque Specs Triumph 10
K TR2/3/3A Steering box drop arm Nut torque value? Triumph 0
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
tr3guy TR2/3/3A TR3 Fan Bolt Torque Triumph 3
Popeye TR4/4A Rear leaf spring bolt torque Triumph 11
M_Pied_Lourd TR2/3/3A Hi Torque Starter Repair Triumph 14
S Torque setting for U-Bolt nuts Austin Healey 12
M TR2/3/3A Has anyone put in a Hi Torque Starter from Moss? Triumph 21
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
S Torque Range? Austin Healey 13
KVH General TR That Front Fan Dog Bolt Again--Torque It Triumph 7
K TR4/4A Gearbox front cover[Moss 848-000] torque spec? Triumph 1
Griz Manifold nut torque Austin Healey 11
B re-torque heads? Austin Healey 5
J Need dimensions for BJ8 PII radius [torque] box carpet flaps. Austin Healey 1
K TR2/3/3A Oil Pan bolt torque spec? Triumph 2
M TR4/4A TR4A - Torque the Front Suspension Trunnion Bolt! Triumph 5
KVH General TR Torque for the Camshaft Bolts Triumph 3
R Cam gear nut correct torque Austin Healey 2
KVH General Tech Torque Question Triumph 5
B High Torque Starter Spridgets 7
C Need Help Finding Torque Specs for Engine Austin Healey 1
C Drive/Propshaft Bolt Torque Spec? Austin Healey 8
S TR2/3/3A torque of the large pulley bolt Triumph 4
I Off Topic Bolt torque specs Triumph 3
Gerry M TR6 1974 TR6 Wheel lug torque Triumph 4
B Spitfire Torque specs on rear spring bolt, Spitfire Mk3 Triumph 2
T TR2/3/3A Front wheel bearings direction and torque Triumph 1
