dklawson
Thanks to a member here I have a pair of short length Spitfire axles I'm reconditioning for my project car. (There is a fatal problem on the RR axle of our '72).
I have removed the flanges from the axles in anticipation of fitting new rear wheel bearings. I have read through my Haynes, Bentley, and AutoBook manuals. I can't find something in the instructions. While I may understand "why" it's not in there, I want to bounce this off those who have done this before.
The instructions talk about where to position the grease flinger disk on the axle shaft and give detailed instructions on where and how to fit the seals, needle bearing, and ball bearing. What they do NOT say is how far the axle is pressed into/through the inner race of the ball bearing.
I have not pressed the axle out of the bearings yet so I haven't seen the "hidden" portions of the shaft. Am I correct that the shaft does NOT have steps/shoulders and that you need to position the exposed, tapered end of the shaft "about" where it was prior to disassembly? Am I also correct assuming that when you tighten the flange onto the shaft that the axle will be “pulled” through the bearing to the correct position? Thus, the small inboard end of the flange would be resting firmly against the inner race of the bearing.
If I’m wrong, please let me know. If there are controlled assembly dimensions I need to work to, please let me know that as well. Thanks.
