[ QUOTE ]
[ QUOTE ]
From Timken's web site:
Seal (Inner): 471224 -- 2 required
Ndle Bearing (Inner): B168 -- 2 required
Ball Bearing (Outer): LS10 -- 2 required
[/ QUOTE ]
These are for both sides. However, there should be two seals. An inner and an outer seal. Timken only lists one of the seals, and it is not clear which one!
[/ QUOTE ]In doing a bit more research online, I find that it is the outer seal that is missing from the Timken list. "GHS111" is the current "factory" part number as shown in Canley Classics' catalogue.
BTW, in doing this online research, I find that both seals and both bearings are available through NAPA! Their online catalogue has a feature where you can search by original part numbers, and all these numbers come up as the appropriate bearing or seal! <napaonline.com> is the site.
