cutlass29
Help please,
Rebuilding spitfire rear half shafts...everything apart no problem, cleaned up and all ready to go back together. PO had at some time replaced seals/bearings....inner seals in hubs are orientated different...one of them is backwards!
Haynes manual says fit inner seal to hub with seal lip trailing...does this mean lip is towards the uj end, so it is trailing when you push it into the hub or is lip towards the center of the hub so it will be trailing when you slide it on the shaft ?
New to the forum and tried the search thingy but struck out.
Any help would be greatly apppreciated.
