Spitfire Spitfire differential rear bushings
tktrain
Greetings! New member here. I'm quite experienced in automotive repair and restoration, but this is my first endeavor in the realm of Spitfires. I have a couple of questions regarding the rear bushings on my '78 Spit differential housing. I purchased new replacements for the car, but my existing bushings seem exceptionally firm and solid with no signs of dry cracking andminimal surface rust in the sleeve hole. I would like advice regarding simply reusing the existing pieces versus installing the new. I also have tapped the bottom of the housing and installed a drain plug to facilitate simple lube changes in the future. My car has the fibre shims behind the planetary side gears and they were missing. I have purchased new fibre replacements as the brass versions are not to be found. Any advice regarding these questions would be greatly appreciated!
This14u
TK,
Had the same question on the diff bushings when I had my Spit apart. Even with replacements on hand, I decided to leave the originals in place. Didn't seem worth the effort as they were in good condition.
T
tktrain
This14u:
Thanks for the input. I'm of the same opinion, Unless someone chimes in with a good reason why not to use the old pieces, I'm just shelving the new ones for now. Thanks again!
T
tktrain
BTW, any thoughts on the durability of the Fibre spacers behind the splined side gears in the planetary assembly? Any sources out there for metal versions? No one seems to have them any longer.
Also, what is the torque specification for the Bearing Cap bolts for the differential carrier? I don't see it listed inmy Haynes manual.
A Spitfire Flush Spitfire Differential? Triumph 4
B Spitfire Spitfire differential question Triumph 4
J Spitfire Differential gear lube level 78 Spitfire Triumph 5
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 5
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 0
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
glemon Spitfire Spitfire Questions Triumph 7
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
T General Tech Spitfire overdrive, the sequel Triumph 3
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
D For Sale Custom 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
glemon Spitfire Spitfire for the Win Triumph 5
P For Sale '78 Spitfire Frame Triumph Classifieds 0
D For Sale For Sale: 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
N For Sale 1971 to 1980 Triumph Spitfire Bonnet Triumph Classifieds 0
TomMull Post-War Other Herald [or Spitfire] fuel pipe Triumph 5
FlyingCat Wanted 1979-80 Spitfire Radiator Mount Bracket and Cradle Triumph Classifieds 0
A Spitfire Spitfire Ride Down The Mountain - Vermont Rt 100 Triumph 12
N For Sale 1979 Triumph Spitfire Triumph Classifieds 2
C Wanted triumph spitfire mk2-3 drivers seat bucket Triumph Classifieds 0
M Hello again. I have a 1978 Triumph spitfire. Triumph 17
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
P For Sale 1975 Spitfire for sale Triumph Classifieds 0
N For Sale Triumph Spitfire hardtop Triumph Classifieds 0
Jerseygirl For Sale Spitfire Factory Hardtop Triumph Classifieds 2
R Wanted WTB Spitfire race/auto cross car Triumph Classifieds 1
PAUL161 Spitfire 75 Triumph Spitfire on Craigslist Tulsa Triumph 1
