Spitfire Spitfire Rear Wheel Flanges-Common Problem or DPO?
dklawson
I know getting the drive flanges off a Spitfire axle is a pain but when doing the task today on the left rear it was "extra" difficult.
When I finally got the flange off, it was obvious why it had been difficult. The key had sheared and the flange spun on the axle. There was material transferred from flange to axle and axle to flange effectively welding them together in spots. The odd thing is, 18 months ago I found almost the same failure on the right rear axle.
Is this a common failure mode on Spitfire axles or am I the victim of a previous owner who did not properly torque/seat the flange on the axle?
Andrew Mace
I suspect you're the victim of <span style="font-style: italic">something</span> the DPO did? Was there evidence that a key actually had been in place....or could it be that the DPO just torqued the living h-e-double-hockey sticks out of the nut in an attempt to cover up for some serious lack of brainpower? :smile:
Bottom line: I've never seen anything quite like what you describe!
dklawson
dklawson
On both sides the key was still present but split in two. On the left side there was evidence that the flange spun several times after the key sheared as the break was polished smooth.
On the right side (18 months ago) we heard bad sounds the first time we took the car up to speed. We ordered a bearing kit before driving again. When we tore that side down we found that the keyway had huge burrs kicked up on both sides (leading and trailing edges) on both the shaft and the inside of the flange. For the repair I bought a pair of axles from a NASS member who took pity on me.
On the left side, we did not hear any bad noises until recently. We were getting some bearing or u-joint ticks. I found the left side damage when tearing things apart to fit a new u-joint and wheel bearing. Like the right side, the flange appears to have spun on the shaft.
It is fortunate that I bought a pair of axles 18 months ago and not just the one I needed at the time.
frankenstang57
Too much HP and oversized sticky rear tires... :p
racingenglishcars
I have done a hundred spitfire axles back when I was working with that stuff. I don't remember ever seeing one spun like that. Rather that they will burn bearings and destroy the axle. I have however had flanges completely deformed while pulling them off, and this is with the factory tool.
dklawson
dklawson
So far between here and the NASS Yahoo group, only one other person has seen the failure I have seen and in that case they knew in hindsight that they didn't put the rear assembly back together correctly. Therefore, I am going to stick by my suspicion that my car is a victim of a previous owner.
Since I had used parts in hand that were in good condition I replaced the components today. I am happy to report that the left rear of the car is now relatively silent. Gone are the bearing or u-joint ticks that prompted me to take the rear end apart.
frankenstang57
Those things are on there so tight I cannot envision a hub spinning on the axle. My vote is to blame the PO. If the PO was such a hack, it makes me wonder how they managed to get the hubs apart in the first place...
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
D Spitfire Spitfire rear wheel pulling Triumph 6
B Spitfire Spitfire Mk3 Rear Wheel FREE CAMBER VALUE Triumph 4
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
J Spitfire Spitfire Rear Brake Bleeding Triumph 9
B Spitfire Torque specs on rear spring bolt, Spitfire Mk3 Triumph 2
spitfun Wanted:Triumph Spitfire race rear spring Racing 2
T Spitfire Spitfire differential rear bushings Triumph 5
R Spitfire Spitfire - Rear Hub disassembly help! Triumph 2
jollyroger Spitfire rear window seal 76 spitfire Triumph 3
S Spitfire spitfire rear brakes Triumph 5
J Spitfire Spitfire Rear Suspension Triumph 8
frankenstang57 Spitfire Spitfire rear suspension problem Triumph 15
D Spitfire spitfire rear spring question Triumph 2
D Spitfire spitfire diff and rear spring Triumph 9
W Spitfire Rear Suspension Sway Bar?? on 1980 Spitfire Triumph 5
D Spitfire 1976 spitfire rear bumper question Triumph 3
JBann Spitfire Rear passenger brake drum smoking - Mk1 Spitfire Triumph 4
eschneider Spitfire Watchpoint - spitfire rear trunnion bushes Triumph 4
eschneider Spitfire Spitfire torque specs - rear upright / trunnion ? Triumph 4
eschneider Spitfire another Spitfire question - stuck rear hubs Triumph 26
pjsmetana Spitfire Rear Diff, Spitfire Questions Triumph 16
dklawson Spitfire Spitfire - Rear Hub Bearing & Axle Assembly Steps? Triumph 17
B Spitfire odd noise from Spitfire rear Triumph 5
dklawson Spitfire Spitfire MkIV - Rear Hub Questions Triumph 4
D Spitfire 1971 Spitfire rear axle - Help! Triumph 3
tr7andtvr Spitfire Spitfire rear suspension part needed??? Triumph 3
R Spitfire Spitfire rear end noise from heck Triumph 14
R Spitfire '75 Spitfire rear fender top trim Triumph 0
dklawson Spitfire Spitfire - Rear Track Width Identification Help Triumph 2
S Spitfire Rear engine mounts - Spitfire Triumph 2
M Spitfire Rear Tires Leaning Out Restoration & Tools 5
B Spitfire Spitfire-rear suspension question Triumph 14
TR_JOE250 Spitfire Spitfire rear suspention problem Triumph 8
eejay56 Spitfire Spitfire rear end noise Triumph 9
cutlass29 Spitfire spitfire rear trunnion bushes Triumph 4
cutlass29 Spitfire spitfire rear hub seals Triumph 6
frankenstang57 Spitfire Spitfire rear hub removal? Triumph 11
middleagecrazy Spitfire 76 Spitfire rear axle bearings Triumph 5
C Spitfire SPITFIRE REAR BRAKES Triumph 5
guzzul Spitfire Spitfire rear hubs - where to position bearing? Triumph 6
cutlass29 Spitfire spitfire mk3 rear engine oil seal Triumph 1
Simon TR4a Spitfire Spitfire rear spring Triumph 1
G Spitfire Spitfire rear suspension Triumph 2
B Spitfire Spitfire Mk1 Rear Anti Roll Bar / Sway Bar Triumph 3
B Spitfire Spitfire Mk1 Rear Spring Shape Triumph 7
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
