Mental
I expected a search for MG Electrical System would lock up my computer. But it came up with nothing.
Jokes aside, I have had a 72 Midget for about 10 months now.
I had the car for about 2 weeks when the alt light started coming on dimly and then the car started loosing charge. I replaced the alternator and the light went off. But the car was only good for three days of use, then dead battery.
I have changed the battery twice. The same problem. No charging light, but three days the car won;t start. Put it on a trickle charger overnight and I get the same use out of it. If it sits for 2 weeks, it will start, but three days of use and it is no good.
After the last battery swap I got about 5 days out of it, but it did the same thing. I can bump it when it does this, and that will get me about 20 more miles before it quits completely.
I cleaned up the ground off the battery and the main ground on the passenger fender (headlights weren't working)
Anyway, 72 Midget, US Spec, no idea how many miles, bad respray sometime ago, some creative wiring in there, but obviously I am missing something. I am a competent parts replacer and sometimes get lucky on diagnostics, but I am just not that good. This is a negative ground car.
I am looking for some tips and some directions to run this little gremlin down. I am sure I am leaving out info you smarter folks need, so ask me and I will do what I can to answer. I only ask you be patient with my lack of knowledge.
I get that is a 38 year old car with odd electrics, I just want to be able to drive it.
I thank all of you for your time.
