Help with new [old] Sprite hardtop
anarchy99
So I finally got a hardtop for my Sprite (64-66) but the weather strip and seals are bad and the plexiglass is old and needs to be replaced. Does anyone have a source or a way to replace the plexiglass? Also a supplier for the seal that goes around the window? I tried searching the internet but didnt come up with much more than a supplier in the UK possibly. Thanks guys.
JPSmit
no sources but, that seems like something you could do locally - is it a flat piece of plexi? even curved, is not that hard, likewise, a local auto glass place might be a good start for seal. - or a trailer manufacturer.
Pythias
nomad
Call Macgregor, he doesn't do internet. I have a Mk3 Sprite hardtop and think it had all glass in the factory hardtop. Is it a factory hardtop? I have to look since I have yet to use it.
Kurt
anarchy99
anarchy99
I doubt it's a factory hardtop, its plexiglass. I need to upload some pics, **** if I could get the plexiglass redone in glass I'd be ecstatic. Wonder if I can just take the curved plexiglass piece in and have it matched. I'm going to look into the seals and give macgregor a call. I appreciate it guys. I cant figure out how to post up pics or else I'd toss the pics up on here. I also scored another hood, since mine has been cut apart and redone several times. Going to install this one and itll be the last one I have to cut a hole in.
JPSmit
Here are the pics of the hardtop
anarchy99
anarchy99
Thanks JP, greatly appreciated. I need to do project journals for the Sprite and Triumph at some point... Triumph is about to be epic!!!
nomad
Well that hardtop isn't factory. Looks an awful lot like a bug eye top.
anarchy99
anarchy99
Pulled it off of a rubber bumper midget in Arkansas. Didnt roll up the windows to see if all was well, it was painted the same as the car and seemed in good order, like it had been on there for awhile. I flew back home and its heading back in a truck so I wont see it for a week or 2. More updates to follow, also got a new straight hood to weld in the Sprite front end, and yes, cut a big hole in it for the bloweršŸ˜ new toy for the Triumph as well... it's been on the back burner for awhile and really looking forward to getting it up in the air and figuring out some stuff on it.
nomad
It does look familiar. Someone should have an idea. You don't mind modifying and I hope you are aware mounts differently from the earlier cars.
anarchy99
anarchy99
Oh yeah, JP, I figured out the posting pics thing... if I click on "go to full site", it gives me the option to post pics but not on the mobile one. Weird
JPSmit
Didn't realize you were using Mobile - I have the same issue. glad it worked.
do you have a triumph thread somewhere?
also, if you google it, it looks like you can polish scratches out of plexi - OTOH a plastics store or a pattern maker might be able to help you form new rear glass
anarchy99
anarchy99
I really wish i could polish them out... did that with an old fish tank coffee table a while back, worked great. Unfortunately the top has tiny cracks throught the whole thing that look like they are from sitting in the sun forever. Once it gets here in a week or 2 I'm going to pull the back plexiglass and see if a local glass place can help with it. Original triumph thread is here, but a ton of updates soon and going to start a project journal soon over on British V8...
http://forum.britishv8.org/read.php?3,52589
JPSmit
another bonkers project! can't say I love the body mods but none the less watching with great interest! You seem to have access to many and interesting engines!
anarchy99
anarchy99
Last one for now, sorry the cars so dirty and cluttered... I've been busy elsewhere lately. More to follow, along with updates to the Sprite in another thread and the triumph as well.
T Old Man needs help MG 11
soren_ak All u OLD CAR fans out there - help me out wuld ya Austin Healey 13
J Wanted Help Wanted -SE WI Other British Classifieds 0
J Help Wanted - SE WI Racing 0
Darwin Spitfire Motor mounting help Triumph 1
Dnickels Spitfire Speedo help Triumph 4
RGK TR5/TR250 SU carb ID help Triumph 6
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
AngliaGT Help Me Identify These Parts Jaguar 6
jlaird MGB V6 carb help MG 14
nichola TR6 Help me - circuit breaker above horn relay Triumph 5
T Bug Eye Heater Switch Help Spridgets 2
G General Tech Help TR-6 Triumph 24
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
S Axle Shaft Installation Difficulty - Help Sought Spridgets 8
R Rust in Block? Help needed! Austin Healey 6
D PDF attachment help FORUM Help 1
M General MG OEM Radio wiring help MG 4
J MGB Need help identifying these parts MG 6
G 1960 3000 BN7 Top Help Austin Healey 0
P Carb Help - Car idle slows and dies after being run for a while Austin Healey 14
B MGB-GT Need help with MGB GT rattle MG 0
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
JPSmit Plywood - woodn't you like to help Restoration & Tools 8
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
Bayless Login problem need help FORUM Help 7
B TR4/4A Help indentifying these Triumph 5
N Please help --- New owner of a 1958 Austin Healey Sprite Spridgets 4
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
6 Master Cylinder Rebuild Help Please Spridgets 3
D photobucket image help FORUM Help 2
TRclassic3 TR4/4A Help with deciphering front suspension problem Triumph 11
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
P A little identification help please Other British Cars 10
R Temperature sensor Help me Austin Healey 18
N Electrical Issues Need Help Austin Healey 8
F I canā€™t remove Wire wheels from new hubs - help Austin Healey 43
C Austin A40 Sport Convertible? Help! Other British Cars 3
JPSmit Alternator help - please. Spridgets 21
A Hello from new member, and car identification help request Other British Cars 9
I Bugeye oil pan help Spridgets 3
vette Renewing Subscription, need help. FORUM Help 1
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
R TR2/3/3A Help, I am stuck, or think I'm stuck Triumph 32
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 6
B TR4/4A Can't get rear extension off. Help! Triumph 24
M Help with 60 Bugeye - major drivetrain issue... Spridgets 78
