link to control head rebuild
donbmw
I have been looking for the link to rebuild a control head. I need to replace the wires in my TR3. I thought I saw this in a post not to long ago.
Don
emmett1010
Hey Don:
This is Emmett from McComb. I met you at the NO show.
I'm putting together the 57 TR3.
Anyways, I tried to repair my control head, only to finally realise that all of the small parts weren't there. I gave up and bought a complete new head.
I have many control head parts, including a new wire harness, and button assembly if you could use them.
The article you are hunting is in the wiki section.
Good luck, Emmett
donbmw
donbmw
Thanks Emmett I will let you know.
Don
MGTF1250Dave
Aloha Don,
Here is a link to a technical archive:
https://www.tr-register.com.au/files/technical.htm
in the second box down is an article written by Clive Elsdon titled "Disassembling the Control Head in the steering column" that provides a description of the process with photos and shows you all the bits inside. Althought the article does not describe reassmbly, you just kind of "reverse engineer" it back together.
Tinkerman
Dave:
I just printed off the article that you referred to. What a find! I know that re-doing the control head is on my list so I was delighted to get the article. Pictures came out clear as a bell also.
Thanks a heap, Tinkerman
donbmw
donbmw
Thanks Dave that was the one I saw awhile back. Turns out the flasher relay quit on me. I am going to save pulling the control for this winter and replace wires and stator tube. I realy don't want to have the car apart right now.
Don
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
Jim_Stevens Off Topic Ethanol-free gas link Triumph 1
D MGB Rear Suspension Damper Link Arm MG 2
banjojambo Triumph tr3 vertical link wobble Triumph 2
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
V TR2/3/3A Vertical link check Triumph 2
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
S TR2/3/3A Vertical link Triumph 3
S TR2/3/3A How bad is this? Vertical link Triumph 12
J TR2/3/3A L/S Vertical Link Resistance Triumph 17
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
N Watts Link??? Spridgets 2
H broken sway bar link - again Austin Healey 8
T TR2/3/3A tr3a verticle link removel question Triumph 11
G BJ-7 Rear Shock Link Austin Healey 2
B Support bracket for the rear suspension damper link Austin Healey 5
D TR4/4A stubborn lever shock link Triumph 2
Geo Hahn TR2/3/3A Vent Lid Link Triumph 3
N Top link offset bushings?? Spridgets 6
Scotsman TR4/4A Front Suspension Vertical Link Triumph 2
mcmillal TR4/4A Broken Vertical Link Triumph 17
T TR5/TR250 250 Sway Bar Link Triumph 0
drooartz General MG Alternator link - adjusting bracket length on MGB? MG 8
T Perished Rubber/etc on BE rear shock absrober link Spridgets 0
DornTRoriginal TR2/3/3A Horizontal Link Assembly Install Question Triumph 1
J TR2/3/3A Need a TR3 vertical link Triumph 1
D TR2/3/3A Vent lid link length Triumph 8
J TR4/4A 67 IRS Damper arm/link removal help Triumph 10
mgedit TR2/3/3A Link Rod Lengths Accelerator Linkage Triumph 2
S TR4/4A Reversing upper fulcrum link Triumph 3
B Parts for sale on Panjo link Austin Healey 0
M_Pied_Lourd TR2/3/3A Verticle Link to Trunnion Fitment Triumph 5
K Jaguar 140 Restoration Link? Jaguar 2
Morris OOS Upper Link Spridgets 6
AHS TR2/3/3A Can someone please measure the scuttle vent door link length? Triumph 2
K TR2/3/3A Silent bloc bushings in the drag link. Triumph 2
BobbyD Off Topic HiJacked Forum Link? Triumph 4
DornTRoriginal TR2/3/3A Carburetor Link Rod Ass'y Installation and Fuel Line Installation Triumph 1
aeronca65t MGB Excellent MGB info-link MG 0
blueosprey90 MGA An Alternate Sway Bar Link for the MGA with MGB Sway Bar [ a repost] MG 1
drambuie Check out this Healey 100 with a Jag V12 convertion [click on the british v8 link] Austin Healey 5
H broken sway bar link Austin Healey 13
TimK How do you post a link to an older post/thread? Austin Healey 4
T TR2/3/3A TR3B vertical link Triumph 13
K Link to pic of 4 inner sill install without floor? Triumph 0
T Help on ball joint - vertical link fit Triumph 20
W Link to my intro Austin Healey 0
Willie_P TR4/4A Custom Shock Link: idea [Tr4] Triumph 1
