TR2/3/3A Silent bloc bushings in the drag link.
karls59tr
I 've read that they are problematic. In what way are they....deterioration of the rubber causing too much play? Anyone tried the Delrin bushings and what kind of a difference did they make?
Geo Hahn
...deterioration of the rubber causing too much play?...
That's been my experience. Easy to see if they are pretty far gone, just watch them as someone wiggles the steering wheel left & right.
In addition to Delrin I think there may be a bronze alternative.
TR3driver
Great Pumpkin - R.I.P
I think they're brass rather than bronze, but no matter. Anyway, I installed them some 25 years ago on my former TR3A and I'm still using them. Did a lot of other things at the same time (Nylatron in the suspension pivots, rebuilt the steering box, etc.) so I can't really say which component had the most effect; but it really transformed the car. Less slop and much lighter steering. They've gotten really pricey though, so I'd go with the Delrin today. (In fact, I bought the Delrin kit with the intention of using it on the TR3, but decided to move the brass ones over from the wrecked TR3A instead.)
The brass ones did require some fitting, though. On one side, I had to add a shim to reduce play, while I had to trim the bushing a bit on the other side to keep it from binding. I also added grease zerks so they could be lubricated occasionally (which the Delrin won't need).
Oh yeah, the positioning of the idler arm bracket seemed to become more critical as well, since the brass doesn't deflect. I fiddled around a bit, getting it lined up with the steering box. (Both of them mount with oversize holes.)
Don Elliott TR2/3/3A Removing TR3A Silent-bloc Bushings Triumph 16
T TR2/3/3A Leaf Spring "Silent Bloc" Triumph 3
T TR2/3/3A TR3 Silent-bloc Bushand Pin Assemblies Triumph 14
CZ_Dave The SILENT Treatment MG 5
T TR2/3/3A TR3A tight steering/silent blocks Triumph 8
ekamm TR2/3/3A Tr3 silent block removal Triumph 2
A TR2/3/3A TR3 Silent block Triumph 7
S TR4/4A TR4[?] silent star in new Chipmunk movie Triumph 2
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 5
R TR6 Lower A-arm trunnion bushings Triumph 17
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
Upland SuperPro trunnion bushings Spridgets 0
R TR2/3/3A Upper Wishbone Bushings Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
tahoe healey Sway Bar Bushings Austin Healey 3
Gliderman8 TR6 Corona boredom relief - Steering Wheel Bushings Triumph 6
B Wanted FOUND. TR10 Fan mount Bushings Triumph Classifieds 3
S TR2/3/3A Clutch cross shaft bushings? Triumph 5
S TR2/3/3A lube for upper A bushings Triumph 2
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
Got_All_4 General TR Has anyone used these poly bushings Triumph 6
D TR2/3/3A steering column bushings Triumph 8
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
mt10flyer TR2/3/3A poly bushings - upper wishbone Triumph 2
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
KVH General TR Pressing in the lower/inner control arm bushings Triumph 3
S TR6 steering column bushings Triumph 5
N Top link offset bushings?? Spridgets 6
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
B TR2/3/3A Inner wishbone bushings Triumph 5
B TR2/3/3A What do you do lubing polyurethane bushings? Triumph 7
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
R TR2/3/3A Front Suspension Polyurethane Bushings Triumph 2
Got_All_4 TR2/3/3A Super pro bushings Triumph 2
Got_All_4 TR2/3/3A Reaming trunnion bushings Triumph 4
Got_All_4 General TR Anyone running superpro bushings? Triumph 3
J TR2/3/3A What is the best way to remove and replace carb shaft bushings. Triumph 4
GTP1960 TR2/3/3A Brass /delrin bushings on rear spring shackle? Triumph 3
tomshobby TR6 Nylatron trailing arm bushings. Triumph 11
M XK140 Sway Bar Bushings Slipping out of Brackets Jaguar 1
J Poly Lower A-Arm Bushings - One easy question as I am confused Austin Healey 1
CJD TR2/3/3A Lower Inner Wishbone Bushings Triumph 2
glemon General TR Those Darn Throttle Shaft Bushings [TR4-6] Triumph 8
S King Pin Bushings Austin Healey 1
C TR4/4A TR4A Differential Mounting Bushings Triumph 6
MY66AH Kingpin Bushings Spridgets 27
T TR4/4A Has anyone used steel gear bushings in their TR4 transmission? Triumph 3
sim Fitting Damper bushings Question Spridgets 5
