I've been rebuilding the front suspension on my 3A frame-off and have a concern. I first completed the left side (minus the spring/spring pan) and noticed some resistance when rotating the vertical link back and forth. Believing I mixed up the left and right vertical links, I switch to the other one - no change in resistance. So I decided to finish the right side for comparison with the left. It seemed to rotate with about half the resistance of the left (I think this light resistance is probably normal). This led me to believe the there is nothing wrong with the other vertical link, so one-at-a-time I replaced and adjusted the left side ball joint, and the trunnion - still no change in resistance. There does not appear to be damage to any of the suspension parts or the frame, so I am not sure what to do next. Will the trunnion simply wear-in? I know my original trunnions seemed to have significantly more play than the new ones. I would appreciate any advice.
Joel
Joel
