TR2/3/3A Installing botton rubber on windshield
Tinkerman
Afternoon, windshield for my 1960 post 60,000 TR is now all assembled except for the stanchions. How do I get the bottom rubber flap started into its groove?
Your thoughts and ideas greatly appreciated.
Tinkerman
Dick
There is a long thread here on BCF about doing that. Lots of soap and water, two people, one to hold and one to pull. I put one in about a month ago. I took the bottom frame which the rubber goes in to, locked it in a vise and pulled the rubber thru that way. Then reassembled the frame. A lot of the new rubber seals are too thick and are very hard to pull through. Hopefully you will have a thinner seal.
Marv
martx-5
Yeah, that's a tough job. Don't cut it to length until it's in and settled for a day or two, and don't put it in backwards. The angle should face towards the BACK of the car when installed. Intuitively, it looks like it should angle forward, but that's wrong.
CJD
I bought from Moss, and it was a very nice seal, molded to the shape of the frame. I learned there was no way I was going to "pull" it through, though. I wound up started in the middle, hooking in the front edge and stuffing the rear with a smooth tipped screw driver. It took a good hour to finish it.
My last seal was from TRF, and it slid in with no problem. It was not molded to shape. I like looking at the Moss seal. I like installing the TRF seal!?!
Tinkerman
Tinkerman
Hi John, are you refering to the top seal or the bottom seal?
Thanks, Dick
CJD
I'm referring to the bottom seal, that stretches from the lower frame to the cowl. The Moss seal appears to be molded rubber...very nice, but very hard to install. The TRF seal was more of an extruded, less rubbery type of rubber.
My upper seal, hood to upper windscreen...slid in relatively easily. I did have to remove one stanchion to slide the upper seal on, though. The groove for the top actually starts at the bottom of the frame sides.
Tinkerman
Tinkerman
Thanks for the info John. All of that is my next task so the info is very timely!
Cheers, Dick
mgedit
Missed this thread when posted. Yes, there has been lost of discussion before. Few points: rubber won't slide into grove, has to be pushed in from side; don't cut in advance, wait a couple of days; use a lubricant (like K-Y Jelly), soap is not supposed to be good for the rubber; make sure the orientation of the rubber is correct (sort of looks backward when correct); use some sort of metal device to ease into place (I used a stable remover); protect the windscreen and work on a solid table; and use masking tape to support the extra length (and mark centre) as you work to make it possible to do job yourself if you take your time. Maybe this picture will help a bit. There are a few other pictures on the TR3 link in my signature. Cheers, Mike
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
S Installing a Radiator Fan Austin Healey 9
G Installing New Rocker Shaft Assembly Austin Healey 3
W Need advice on installing new side curtain glass Spridgets 1
Bayless Help please installing bonnet release cable Spridgets 8
M TR6 Installing Retrosound? Triumph 4
S TR2/3/3A Installing the distributor pedestal. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
A TR6 Installing differential and transmission Triumph 10
Z Installing Toe Board Panels Austin Healey 1
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
B Installing cam bearings 1275, can I do it? Spridgets 1
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
T Installing Garmin GPS in a BJ7 Austin Healey 19
F Installing AC in my 1960 Healey Austin Healey 14
S TR2/3/3A technique for installing a door Triumph 5
R TR2/3/3A Installing wiring harness in steering column Triumph 59
R TR2/3/3A Installing gas tank Triumph 6
C Installing rubber grommets in firewall? Austin Healey 6
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
S TR2/3/3A installing the wiring harness Triumph 8
R Installing Sprite Luggage Rack Spridgets 9
Lukens TR2/3/3A Installing a throttle. Triumph 2
J Powertune booster for a bj8 , trouble installing Austin Healey 2
B TR2/3/3A Installing dzus fastners in bonnet Triumph 8
D Prepping Floors Before Installing Interior Restoration & Tools 6
drooartz Installing front hubs, tips? Spridgets 15
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
D BT7 tri-carb installing my crank Austin Healey 4
aero3113 Installing Front rotors to hubs Austin Healey 2
C Advice for installing a 3000 Grille??? Austin Healey 7
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
S TR4/4A procedure for installing gauges etc Triumph 0
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
55modified Help installing toggle dip switch on dash for lights. Austin Healey 23
TRMark TR4/4A Installing a new windscreen Triumph 9
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
T Installing a Lucas 16 ACR alternator on Bugeye Spridgets 10
KVH General Tech Installing the Pistons and Rings Triumph 7
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
6 General Tech Installing New Oil Pressure Gauge MG 5
6 Installing Oil Pressure Gauge Spridgets 2
T TR4/4A Installing wheel arch covers in a Tr4a Triumph 0
K TR2/3/3A Installing a Voltmeter on a TR3? Triumph 10
