Filling overdrive oil on BJ-7
Keoke
robert_ellison said:
Where does one fill the overdrive with oil on a BJ-7.
:savewave:
Using the transmission filler plug Bob, be sure you have the car on the level when you do it.---Keoke
If filling the xmsn from "dry" recheck the level and top up after running the overdrive unit (on jackstands, if you're careful, or just a trip around the block, if you can engage the ovd.).
The overdrive unit will "consume" some additional oil, to fill up the operating circuits.
glemon
When I had my early 100 tranny and O/D rebuilt the mechanic that worked on it suggested refilling with the front of the car elevated, I don't know if it is absolutely necessary, but can't hurt (as long as you don't overfill it) and might help to make sure enough oil flows back to the O/D
Keoke
I don't know Glemon, but I feel that the potential for overfilling the OD is increased using that method.--Keoke
glemon
I would agree, and in fact I filled mine on the level after the rebuild and...no overdrive...I refilled using the method suggested by my rebuilder and the O/D worked, have no idea if it was having the car tipped up or ther right wire got jostled or some little piece of debris in an oilway got moved. And in deference due respect to the late great PH, now you know the rest of the story....
Probably best to fill on the flat to the recommended level and give it time to move into all the parts and see how it goes.
If one were to tip the car before filling one would of course measure the fluid put into the box for correct factory specs with and O/D box.
Greg
D Filling Holes Austin Healey 21
steveg TR6 Cooling system filling Triumph 7
S Filling Steering Gearbox with Castrol Hypoy Process Austin Healey 10
maxwedge5281 sxplash or overflow when filling healey gas tank Austin Healey 6
T Filling an Armstrong Lever Arm Shock Spridgets 0
T Filling for an Armstrong shock Spridgets 1
Gearhead_Garage Fuel backup while filling Austin Healey 24
D Location of gearbox/transmission filling area Spridgets 12
N Filling holes??? Spridgets 16
H TR6 Filling up the TR6, overflow? Triumph 6
T filling/flushing steering rack Spridgets 7
T Revised fuel tank filling strategy - re ethonal Triumph 5
TRMark TR4/4A Shorten the radiator filling neck on a TR4? Triumph 7
T over-filling the gas tank Austin Healey 30
BOBBYR Filling my O/D transmission Austin Healey 8
CCURTISS TR2/3/3A Filling TR3 Steering Box Triumph 10
B Filling SU Dampers? Spridgets 20
A Filling Coolant Spridgets 6
G Checking & filling shock absorber fluid Spridgets 9
Johnny Filling differential Austin Healey 4
DerekJ Gearbox oil level and over-filling Austin Healey 11
L Filling shocks MG 16
T Filling rear Bugeye shocks - any tips? Spridgets 7
G Filling a completely dry cooling system.... Triumph 13
M Filling up with Gas MG 11
R question on filling rear shock....[armstrong] MG 3
Obtong Filling Steering Rack/Boots MG 6
K Filling a grease gun Restoration & Tools 9
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
